oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
Stock 76 2.0, I have searched the top of the engine for the Auxiliary Air Regulator, no luck. I have two small vacuum hoses going to the throttle body above the throttle plate. One of those small hoses goes directly to the dizzy vac, the other hose above the throttle body goes to a tee, then one leg from that tee goes to the other side of the dizzy and the other leg from that tee goes to a large silver disk connected to the egr pipe on the other side. I see a small can on the passenger side wheel well with three vacuum hoses coming off, (two large, one small) but no electric wire. Two of the three vacuum hoses (one small, one larger) coming from that small can go to below the throttle body and the other goes to the air cleaner. There is no part with two vacuum hoses and a wire anywhere that I can find, help!
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Looks like you're looking in the wrong spot. The AAR should be on the driver's side, sort of between the manifold and the oil fill tower. Remove the air box cleaner and you will have a better chance to see it.
In the diagram below, courtesy of Mr. Bowlsby, you can see it. Two hoses (red) coming off it next to the "OEL" tower. (IMG:http://www.914world.com/bbs2/uploads_offsite/members.rennlist.com-17042-1485858332.1.jpg) Here's an actual pic of one: (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-17042-1485858333.2.jpg) |
Lo-Fi Version | Time is now: 26th June 2024 - 04:34 AM |
