Can't find an auxiliary air regulator anywhere, Where's it hiding? |
oakdalecurtis |
Jan 31 2017, 02:20 AM
Oakdalecurtis Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Stock 76 2.0, I have searched the top of the engine for the Auxiliary Air Regulator, no luck. I have two small vacuum hoses going to the throttle body above the throttle plate. One of those small hoses goes directly to the dizzy vac, the other hose above the throttle body goes to a tee, then one leg from that tee goes to the other side of the dizzy and the other leg from that tee goes to a large silver disk connected to the egr pipe on the other side. I see a small can on the passenger side wheel well with three vacuum hoses coming off, (two large, one small) but no electric wire. Two of the three vacuum hoses (one small, one larger) coming from that small can go to below the throttle body and the other goes to the air cleaner. There is no part with two vacuum hoses and a wire anywhere that I can find, help!
PlantMan |
Jan 31 2017, 02:22 PM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Usually driver side just behind the oil fill and will have a couple hose coming out of it.
Lo-Fi Version | Time is now: 26th June 2024 - 04:50 AM |
