billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Been thinking about my needs and realize that I not only need a conditioned work and storage place but I also need long term dry storage.
One big building would be nice. However, a large portion of it would be storage. That would be expensive to heat and cool. For the same money (actually a little less) I'm going with two 1200 sq. ft. garages linked by a 30' pad (the one in the drawing is 20' to save space on the drawing). This pad would give me a place to wash cars and work outside on nice days. The buildings will have 10' roll up doors on each end, one walk out door and two windows (around 6'-7' up for security) which are not shown in my rough drawing. The drawing is to scale with the cars being current 911 sized I put the deposit down today and have a few days to make any last minute adjustments. I had lots of good suggestions last time that I will be incorporating such as a loft (not shown on the drawings) . Based on previous feedback I need to spend more time thinking the layout of the bathroom (if I have one) and sink areas. The tool and storage rooms drawn are just for me to think about. Interior layout is something I will add later after the building are up. So, is there a fatal flaw or anything I am overlooking in this design? As I mentioned, I have a few days to make changes before the design/build process kicks off. Slab will be poured in around 4 weeks and building go up in 6 to 8 weeks. ![]() |
billh1963 |
Well, I did go back to see about increasing the size of the buildings. However, they have already started cutting steel.
So, I think the latest layout will work. Using the suggestion of angling the lifts, I think this gives me plenty of room for working (the first shop is the workshop) and plenty of room for storage. I can enclose the space in between the two shops later on for a "dirt work area" as needed. Worst case I can cover it. ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Well, I did go back to see about increasing the size of the buildings. However, they have already started cutting steel. So, I think the latest layout will work. Using the suggestion of angling the lifts, I think this gives me plenty of room for working (the first shop is the workshop) and plenty of room for storage. I can enclose the space in between the two shops later on for a "dirt work area" as needed. Worst case I can cover it. ![]() I think you'll like that shop arrangement. You've given yourself a lot of open space. Be sure to give yourself plenty of room to circulate around the two post. An additional benefit is that you'll be able to use the aisle way for quick projects that don't require the lift. Enjoy! |
Lo-Fi Version | Time is now: 28th June 2024 - 12:14 AM |
