vin man |
Member ![]() ![]() Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region ![]() |
I've done some searching and have not yet found a thread that I'm sure has been covered at some point.
The tach in my 72 does not work. The car was converted from fuel injection to carbs long ago. I believe the reason the tach does not work is because it is no longer getting a signal from the computer (no longer have an ECU in the car). How does one use the factory tach when I no longer have FI? In other car projects, I just ran a line from negative side of the coil to the back of the tach. But I don't think that will work here, will it? |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
vin man |
The black/purple stripe wire should enter on the 14 pin connector at pin 7. It continues thru the relay board and exits pin 5 of the 12 pin connector. You should check the 12 pin connector on the relay board, if you take a peek you will see a black/purple stripe wire. Follow it, see where it goes. ![]() Is the 12 pin the one closer to the firewall? That is the one that I spliced on to and ran to the coil. If not, I will look to see if I find a black/purple wire on the other connector and see where it goes. It definitely wasn't on the coil. |
Lo-Fi Version | Time is now: 8th April 2025 - 12:30 PM |
