> Attaching Porsche engine grille letters, Anyone ever try double stick tape?
NJTom
post Feb 21 2017, 07:15 AM
Just wondering if anyone has any experience using automotive double stick tape to adhere the letters to the grille. A hot rod buddy of mine says he and his friends have been using it for years. Told me cut out the exact size for each letter and put on. Since I've got about half the studs he told me just push them through the tape. My mechanic is concerned about the excessive heat and thinks that will cause a problem. Thanks!
Rand
post Feb 21 2017, 11:20 AM
Cross Member
It's the cool air intake. The only time it gets hot there is right after you shut your car off and some heat rises from the engine compartment. I seriously doubt it ever gets hot enough to melt double stick tape. Easy enough to test before drawing a final conclusion.
But as Tom referenced, the mesh / expanded metal isn't the best surface for pressure sensitive foam tape compared to a solid flat surface.
Give it a try and let us know! (IMG:style_emoticons/default/smile.gif)
NJTom   Attaching Porsche engine grille letters   Feb 21 2017, 07:15 AM
Tom_T   I'd be concerned about heat making the adhesiv...   Feb 21 2017, 10:43 AM
Rand   It's the cool air intake. The only time it get...   Feb 21 2017, 11:20 AM
NJTom   Thanks you!   Feb 21 2017, 11:58 AM
Spoke   one way to look at it is the letters are not good ...   Feb 21 2017, 12:03 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:12 PM
