Brake Upgrades for a 4 lug, what's available |
76-914 |
Oct 30 2016, 08:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looking to upgrade my present brake system but I want to keep it 4 lug AND keep the parking brake. Not to mention, staying out of the Poor House at the same time. I'm not opposed to moving up to a larger MC. Is there such an animal? TIA, Kent (IMG:style_emoticons/default/beerchug.gif)
zach914v8 |
Jan 20 2017, 09:46 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
I think for 90% of the 914's out there, the stock system working correctly is great. It is us, the 10% that have scary fast cars that need more. Its a strange feeling when your at the end of a drag strip trying to slow down from 115 mph and see the end of the road come up fast and your car wont stop. When you get out of the car and see you rotors glowing, you know that you have maxed out your brakes.
stugray |
Jan 20 2017, 11:39 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I think for 90% of the 914's out there, the stock system working correctly is great. It is us, the 10% that have scary fast cars that need more. Its a strange feeling when your at the end of a drag strip trying to slow down from 115 mph and see the end of the road come up fast and your car wont stop. When you get out of the car and see you rotors glowing, you know that you have maxed out your brakes. If you are maxing out your brakes from one drag racing pass you are doing something seriously wrong. That would barely give them a workout compared to how I abuse my stock brakes on the track. I brake about as hard as I can from 110 MPH (with 215 Hoosiers) on just one of 10 corners at the track, and do that for 20 minutes without stopping. I have only detected brake fade a few times |
jmitro |
Feb 21 2017, 10:56 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
bumping this thread as I'm contemplating my options for brakes (vented rotors??) on the car for occasional track use. Car will be close to stock weight, I weigh 175lb, and the engine will be 120hp.
I have brand new solid rotors with PMB 5lug conversion, rebuilt calipers, new pads, lines, proportioning valve, 19mm master cylinder. I brake about as hard as I can from 110 MPH (with 215 Hoosiers) on just one of 10 corners at the track, and do that for 20 minutes without stopping. I have only detected brake fade a few times based on your experience, I'm thinking my desire for vented rotors is probably not necessary? thoughts? I'm using my stock Boge strut bodies; if I want vented rotors using Porsche calipers and 5lug, I'm assuming the only option is to convert to 911 front struts? |
stugray |
Feb 21 2017, 11:08 AM
bumping this thread as I'm contemplating my options for brakes (vented rotors??) on the car for occasional track use. Car will be close to stock weight, I weigh 175lb, and the engine will be 120hp. I have brand new solid rotors with PMB 5lug conversion, rebuilt calipers, new pads, lines, proportioning valve, 19mm master cylinder. I brake about as hard as I can from 110 MPH (with 215 Hoosiers) on just one of 10 corners at the track, and do that for 20 minutes without stopping. I have only detected brake fade a few times based on your experience, I'm thinking my desire for vented rotors is probably not necessary? thoughts? I'm using my stock Boge strut bodies; if I want vented rotors using Porsche calipers and 5lug, I'm assuming the only option is to convert to 911 front struts? I have heard many horror stories about vented rotors cracking on track cars. There certainly are those that do it, but would it be a benefit for your application? I would say if have have moderate HP (stock to ~150hp) then you might not need the extra heat dissipation. It also depends on how you drive. |
jd74914 |
Feb 21 2017, 11:33 AM
Its alive Group: Members Posts: 4,818 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I have heard many horror stories about vented rotors cracking on track cars. There certainly are those that do it, but would it be a benefit for your application? Vented rotors cracking? Drilled rotors-most certainly, but vented are pretty robust. (IMG:style_emoticons/default/smile.gif) |
stugray |
Feb 21 2017, 05:14 PM
I have heard many horror stories about vented rotors cracking on track cars. There certainly are those that do it, but would it be a benefit for your application? Vented rotors cracking? Drilled rotors-most certainly, but vented are pretty robust. (IMG:style_emoticons/default/smile.gif) Sorry. Since he was talking about 4-lug upgrades and vented rotors, I thought 'drilled rotor'. Yes if you have 911 style vented rotors, then they do not crack like stock (solid) drilled rotors. |
Lo-Fi Version | Time is now: 27th December 2024 - 04:41 AM |
