GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
As I have no bodywork experience, I wonder if it's standard to completely cover the body with filler, then sand it down (as seen on many of the Velocity Channel restoration shows) before applying primer and color coats? Obviously this amount of hand crafting is not done during initial manufacturing, but is there an advantage to this? Seems a high build sealing primer would make this unnecessary.
Unobtanium-inc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None ![]() ![]() |
Is it a "correct" way to restore, no, but does it happen, all day every day. In fact many shops have gone to the spray bondo. A friend who has a 356 shop said he picked up a trick from the Vette guys and sprays filler right out of the gun, put a nice layer on the whole car and sand down. Bondo itself if frowned upon but one of the best 356 restorers once made the comment that if the Factory would have had bondo they would have used it. In a sense they did use the bondo of the day, which was lead, and they used that very liberaly, I mean layed it on thick like frosting a cake.
So for the average dude, doing an average car, bondo away, the car will thank you. What is and always will be a no-no is to bondo over rust, it is a sin that will come back to haunt you and fast, but for minor body work, lay on the mud! |
Lo-Fi Version | Time is now: 26th June 2024 - 01:22 PM |
