Bgyglfr |
Member ![]() ![]() Group: Members Posts: 55 Joined: 6-December 14 From: Springfield IL Member No.: 18,191 Region Association: Upper MidWest ![]() |
Bgyglfr |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I snuck out to the shop again today. Not a lot of progress but I did clean up the interior. I think it turned out good. The carpet is in decent shape but it has that distinct rodent smell. Hopefully i can shampoo that out. Otherwise I will replace the carpets. ![]() I've had great luck washing rugs with supermarket carpet shampoo. If your rugs are not worn out or threadbare remove them and lay them out in the driveway. Follow the directions for the shampoo using warm water and scrub away. Rinse w/fresh water and hang out to dry. You'll be surprised. Oh yeah, nice car ! |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
I snuck out to the shop again today. Not a lot of progress but I did clean up the interior. I think it turned out good. The carpet is in decent shape but it has that distinct rodent smell. Hopefully i can shampoo that out. Otherwise I will replace the carpets. ![]() I've had great luck washing rugs with supermarket carpet shampoo. If your rugs are not worn out or threadbare remove them and lay them out in the driveway. Follow the directions for the shampoo using warm water and scrub away. Rinse w/fresh water and hang out to dry. You'll be surprised. Oh yeah, nice car ! If after the clean you can leave it out in the fresh air and good sun - Works wonders. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I snuck out to the shop again today. Not a lot of progress but I did clean up the interior. I think it turned out good. The carpet is in decent shape but it has that distinct rodent smell. Hopefully i can shampoo that out. Otherwise I will replace the carpets. ![]() I've had great luck washing rugs with supermarket carpet shampoo. If your rugs are not worn out or threadbare remove them and lay them out in the driveway. Follow the directions for the shampoo using warm water and scrub away. Rinse w/fresh water and hang out to dry. You'll be surprised. Oh yeah, nice car ! If after the clean you can leave it out in the fresh air and good sun - Works wonders. Take it to a commercial laundry mat and run it through one of their machines. If you can't do that, take it to a do it yourself carwash, soap it up and powerwash it out. Or at least soak it in a big bucket. If you don't get all the rodent residue out, it will smell every time there's humidity in the air. You also need to run a vacuum hose from the engine compartment up the longs. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:25 PM |
