Flywheel for 6-conversion to 901 gearbox, Vendors disagree on part no. |
rwfms |
Mar 6 2017, 09:30 PM
Newbie Group: Members Posts: 17 Joined: 4-January 06 From: Wichita, KS Member No.: 5,365 |
I bought a new 901-102-026-01 OEM flywheel which was recommended for a 6 conversion using the stock 901 gearbox. After 7000 miles the ring gear is toast but the starter gear looks ok. I suspect the problem is with the starter/starter gear. While searching for a new flywheel I found vendors don't necessarily agree on the part number. One vendor carries only the -01 wheel specifically for this application. The other vendor carries a -01 and a -02, both OEM, and insists the -02 is the only one that fits. Anyone know if there is a difference in the two wheels or is it just a vendor numbering issue? Also any thoughts on the ring gear problem?
If anyone has a new or like new flywheel for this app you are looking to sell, I'm in the market. Thanks Ron |
jd74914 |
Mar 7 2017, 08:21 AM
Its alive Group: Members Posts: 4,796 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
IIRC some of the high-torque starters have gear engagement depth problems and need to be shimmed.
Lo-Fi Version | Time is now: 24th September 2024 - 01:16 PM |
