mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
So I'm getting ready to leave for the Phoenix club, start the car and I shake the gear lever, feels different, a bit loose, as I'm shaking it I notice it swivels, the shift lever rotates 360 degrees!
I Try shifting, it works as long as I shift according to the pattern, I can shift normaly but I have to be aware of the correct movement. Has this happen to anyone else? Any solution? Thanks Mike |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Well this is great news.
I have a Weltmeister that has a very short lever. I can heat it, remove the original lever and either glue or weld a longer original in the short shift bottom. |
rgalla9146 |
Well this is great news. I have a Weltmeister that has a very short lever. I can heat it, remove the original lever and either glue or weld a longer original in the short shift bottom. Well...not so fast. The Weltmeister I have is welded. Beautiful TIG with original black paint top to bottom. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:11 AM |
