mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So I have been working on restoring little parts along the way of my build. I have also collected the airfilter housing (stock) and the buckets for the carbs. I noticed after I sand blasted the parts and got them ready for plating and powdercoating that they are different slightly. The clips are of different sizes (length) and I can only assume that this is a difference between carb and MFI bases? any idea? Which is for what?
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
So I have been working on restoring little parts along the way of my build. I have also collected the airfilter housing (stock) and the buckets for the carbs. I noticed after I sand blasted the parts and got them ready for plating and powdercoating that they are different slightly. The clips are of different sizes (length) and I can only assume that this is a difference between carb and MFI bases? any idea? Which is for what? Not sure about the MFI ones but 2 clips on my carb bases were different and I found they were bent ,they are fairly springy steel but still bend back straight,did you find rust under the rubber sealing rings of the bases ? |
Lo-Fi Version | Time is now: 26th June 2024 - 07:06 AM |
