McLovin |
Member ![]() ![]() Group: Members Posts: 110 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States ![]() |
Question for the group:
The bounce test is when you open all the doors, take off the roof, and jump up and down on the passenger side. Then you try to close the doors and see if they close easily. Suppose your car fails the bounce test. It's clear that the car would need major surgery in the form of rust repair and reinforcing. But if you do the bounce test and fail, did you just bend the car? Is straightening it as simple as putting a jack under it? Or would you need to do something more elaborate? Has anyone been down that road? Thanks, Mclovin |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Question for the group: The bounce test is when you open all the doors, take off the roof, and jump up and down on the passenger side. Then you try to close the doors and see if they close easily. Suppose your car fails the bounce test. It's clear that the car would need major surgery in the form of rust repair and reinforcing. But if you do the bounce test and fail, did you just bend the car? Is straightening it as simple as putting a jack under it? Or would you need to do something more elaborate? Has anyone been down that road? Thanks, Mclovin This one failed that test: ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 08:12 PM |
