Flywheel for 6-conversion to 901 gearbox, Vendors disagree on part no. |
rwfms |
Mar 6 2017, 09:30 PM
Newbie Group: Members Posts: 17 Joined: 4-January 06 From: Wichita, KS Member No.: 5,365 |
I bought a new 901-102-026-01 OEM flywheel which was recommended for a 6 conversion using the stock 901 gearbox. After 7000 miles the ring gear is toast but the starter gear looks ok. I suspect the problem is with the starter/starter gear. While searching for a new flywheel I found vendors don't necessarily agree on the part number. One vendor carries only the -01 wheel specifically for this application. The other vendor carries a -01 and a -02, both OEM, and insists the -02 is the only one that fits. Anyone know if there is a difference in the two wheels or is it just a vendor numbering issue? Also any thoughts on the ring gear problem?
If anyone has a new or like new flywheel for this app you are looking to sell, I'm in the market. Thanks Ron |
914Sixer |
Mar 7 2017, 07:10 PM
914 Guru Group: Members Posts: 8,922 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I prefer the 74- up 911 starter. The starter is 1.5 hp, almost twice the horsepower of the .8 stock starter. Plug and play. It is best to up the gauge of the cable from the battery to the starter when you make the upgrade.
Lo-Fi Version | Time is now: 28th June 2024 - 06:23 AM |
