Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I have a good 2.7 core, good case, std crank, good heads that are half done on rebuild and some new parts already.
Would it be worth building as an on spec (for sale) rebuilt engine? It would be done right, likely mild performance with JE pistons, replated cylinders, new valves and cams. I can even twin plug it. What about turnkey? I have a fan, cooler, shroud, etc. and I might update my 914 intake so I could even do webers. What would it be worth? Should I do stock or mild performance? Long block or turn key? I've tried selling as a core a couple years ago, but no one was interested except for a couple of lowballers. Now /6 prices are going up and up, but the 2.7 still seems to be considered the bastard child. Not fishing for a sale, too busy to do this right now, just wondering if it's worth doing on spec. |
Bgyglfr |
Member ![]() ![]() Group: Members Posts: 55 Joined: 6-December 14 From: Springfield IL Member No.: 18,191 Region Association: Upper MidWest ![]() |
Speaking for the long block alone, Thanks biggest concern for any buyer would be the case modifications necessary to make it a long lasting motor (line bore, oil bypass, case savers, shuffle pin, etc). Check Ollies for pricing. General rule of thumb is $2k in case work. If those are done properly and documented, the motor would be valuable. Without those mods, many will question the quality of the build and you won't be able to get much more than core money. $2-$3k. A properly built, well documented 2.7 hot rod long block can be approaching $10k built. I've seen RS spec motors (including mfi) go upwards of $20k.
Mark Henry |
Speaking for the long block alone, Thanks biggest concern for any buyer would be the case modifications necessary to make it a long lasting motor (line bore, oil bypass, case savers, shuffle pin, etc). Check Ollies for pricing. General rule of thumb is $2k in case work. If those are done properly and documented, the motor would be valuable. Without those mods, many will question the quality of the build and you won't be able to get much more than core money. $2-$3k. A properly built, well documented 2.7 hot rod long block can be approaching $10k built. I've seen RS spec motors (including mfi) go upwards of $20k. Price wise I think you're at least 5 years behind the times. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 11:13 AM |
