nomedulla |
NOMEDULLA ![]() Group: Members Posts: 32 Joined: 22-March 06 From: SWFLA Member No.: 5,759 Region Association: South East States ![]() |
EDIT
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Ok,
First off fix the valves. Stop looking at TDC and JUST look at the rockers on both sides with the valve covers off. Rotate the engine with one wheel on the ground , engine in 5th gear. Rotate rear wheel in reverse until both valves you are looking at are closed and both rockers are loose. OR, rotate the engine until the valve it open all the way, then go to the same valve on the other side of the motor, it will be closed, adjust it. The second method is even more precise. You adjusted the valves wrong.... Use this method above or go read Capn Crustys valve adjustment article in the frequent tech articles forum here, same deal but he may have explained it better than me. |
nomedulla |
[quote name='r_towle' post='2463434' date='Mar 12 2017, 04:48 PM']
Ok, First off fix the valves. Stop looking at TDC and JUST look at the rockers on both sides with the valve covers off. Rotate the engine with one wheel on the ground , engine in 5th gear. Rotate rear wheel in reverse until both valves you are looking at are closed and both rockers are loose. OR, rotate the engine until the valve it open all the way, then go to the same valve on the other side of the motor, it will be closed, adjust it. The second method is even more precise. You adjusted the valves wrong.... Use this method above or go read Capn Crustys valve adjustment article in the frequent tech articles forum here, same deal but he may have explained it better than me. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:08 PM |
