stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I currently have my car lowered for racing.
Brant tells me that I will likely blow out a shock because I have almost zero travel left. I also need to add another ~1 degree of camber for the Hoosiers. So I want to buy the Elephant Racing offset (decambered) balljoints: http://www.elephantracing.com/suspension/b...14balljoint.htm They take the wedge bolt style of fastener. My car is a 71 so I assume that I have early spindles. One side of my car has the round bolt holding the balljoint in, the other side has the wedge bolt. The PO must have replaced just one balljoint. So if I want to install these balljoints on an early spindle, will that be a problem? And if I want raised spindles, would I be better off buying a set of late spindles to raise? I also learned that you can swap early versus late rotors, but you have to swap the calipers with them. So I currently have late rotors and calipers on the early strut/spindles. bdstone already gave me some advice but I figured I should some get some thoughts from others who have done this already. And does anyone have a set of late lowered spindles for sale? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Sounds like you have one of each. Ditch the early one, get a late one, then have them done. The late ones have the wedge pin.
--DD |
Lo-Fi Version | Time is now: 20th June 2024 - 05:29 AM |
