> Fuel gauge conversion from oil pressure guage?
Eddie914
post Oct 3 2004, 10:59 PM
Unregistered
I don't have a fuel gauge since it was replaced with a combo oil pressure/temp gauge for the 2.7 6 cylinder.
I have heard that an oil pressure gauge can be converted for use as a fuel guage. Geoff told me that there is a thread that describes the conversion. I have tried looking at the classic threads and performing a search, but have had no luck.
Can anybody help me?
Eddie
lapuwali
post Oct 25 2004, 09:39 PM
Not another one!
Just buying that gauge would probably be expensive, however, I believe the way they make it is to use a 924 or 944 combo gauge, remove the idiot lights on the sides, and swap in VDO gauge modules. You could theoretically construct something similar yourself using used gauges from Ebay or suchlike. I don't know how you'd do the voltmeter, but the others are easy. Alternatively, look at the thread on this board about 904 style gauges, which are three gauges (oil temp/press, and fuel) in one combo gauge, assembled yourself from used bits and some custom bits.
Eddie914   Fuel gauge conversion from oil pressure guage?   Oct 3 2004, 10:59 PM
ChrisReale   I dont want to change the subject, but I have a 93...   Oct 3 2004, 11:38 PM
Dr Evil   If it is the 911 style dual side gauge like the on...   Oct 4 2004, 12:33 AM
Dr Evil   Here is the 911 gauge   Oct 4 2004, 12:37 AM
Dr Evil   Optional VDO #3309556   Oct 4 2004, 12:39 AM
lapuwali   I think the idea is he wants to keep the combo gau...   Oct 4 2004, 09:33 AM
914forme   Why not run a triple gauge, I made up a bunch a wh...   Oct 4 2004, 09:46 AM
Bleyseng   I did the conversion of a stock oil TEMP center co...   Oct 4 2004, 10:00 AM
Dr Evil   Lapuwali, they are at the place that you mentioned...   Oct 4 2004, 10:10 AM
Root_Werks   <...   Oct 4 2004, 10:15 AM
Aaron Cox   make more!!!! and make em cheap...   Oct 4 2004, 10:23 AM
Root_Werks     Oct 4 2004, 10:32 AM
Bleyseng   I find the triple gauge to busy as all the gauges ...   Oct 4 2004, 10:57 AM
Dr Evil   Ok Geoff, You want a larger one? Here is a 2 5/8" ...   Oct 4 2004, 11:12 AM
Bleyseng   As it notes its discontinued and I couldn't ob...   Oct 4 2004, 11:29 AM
Eddie914   Geoff, Thanks! That's the idea I now reme...   Oct 4 2004, 12:17 PM
lapuwali   Evil, I know about egauges, I've ordered a bun...   Oct 4 2004, 12:23 PM
Dr Evil   301-601 is the second one downa dn is not disconti...   Oct 4 2004, 12:29 PM
lapuwali   The VDO float type "universal" sender is 10-180ohm...   Oct 4 2004, 01:05 PM
Dr Evil   Lapuwali, according to both the people at NH speed...   Oct 4 2004, 02:16 PM
lapuwali   I got my numbers by hooking a DMM up to a fuel sen...   Oct 4 2004, 03:06 PM
Dr Evil   James, I didn't get a notice that you replied...   Oct 25 2004, 08:26 PM
Dr Evil   Here is an option if the stock sender is not 10-18...   Oct 25 2004, 08:38 PM
lapuwali   Just buying that gauge would probably be expensive...   Oct 25 2004, 09:39 PM
- Lo-Fi Version Time is now: 4th February 2025 - 02:45 PM
