Keith914 |
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California ![]() |
Just tested my latest attempt to stop a bad oil leak (teaspoon of oil on the floor after a good run and park in my garage!). After an earlier attempt to stop oil leaking via replacing the pushrod tubes with new ones from EMW and using ThreeBond Silicone Liquid Gasket 1211 (thanks for the tip Forrest), which did reduce the leaks, I noticed oil dripping from the lower middle case through bolt (IMG:style_emoticons/default/mad.gif) . Only way to access it is to remove the engine, then the tubes and push rods that gives access to the lower tin, remove the lower tin and the rest of the tin to access both ends of these middle through bolts. I loosened these two bolts, one at a time , cleaned the threads and seat areas inserted the same 1211 liquid seal on both ends, and retorqued these two middle bolts, one at time.
So far no more oil leaks -- more lessons learned (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 08:55 AM |
