Blaupunkt Frankfurt wiring question |
GaroldShaffer |
Mar 16 2017, 07:28 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
So I'm going through my stash of radios and want to test them. I have this Blaupunkt radio and just want to verify where the ground goes. In the last two pictures the red arrow is +12V but is the tab on the last picture for ground or the spade next to the +12V in the 2nd to last picture. Or is it neither?
Oh and what size fuse is used? 2 amp? I found some radio sites online but nothing that tells me for sure what ground is and what size fuse. Attached image(s) |
GeorgeRud |
Mar 16 2017, 07:45 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Ground the radio onto the tab on the other side of the radio's back from where the power attaches (second picture). I think the small connector in the small hole may be there for activating a power antenna. Banana plugs will work for the speaker connections.
If you do get one powered up, please check that the small connector does in fact power on and off with the radio, and let everyone know. Mike Fitton may have more info if needed. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:27 PM |
