901 ZF LSD rebuild, 30 years of parts collecting pays off |
mgphoto |
Feb 18 2016, 01:40 PM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I started collecting parts of this project 30 years ago and the last parts have fallen into place. In this post I hope to clear up some confusion and convey some of what I found trying to complete this project. First piece purchased form PAR in Yonkers NY 1986 914.332.209.00 casting number 51D The LSD found its way to me in 2013 from the venerable Cap'n Krusty The diff needed some work as it was missing internal spring plates which are NLA. Item number 4 in this factory illustration. This part places tension on the clutch pack which is measured as drag. The factory spec on this is 29 - 58 ft. lbs This item can be replaced by what is now called a "cup" spring from and early 928 part no. 928.332.555.00 seen here as item number 10 As for the internal wear parts, the 914 parts are NLA but, get this they are replaced by mostly 917 parts! WAY COOL. Just the beginning, stay tuned! Mike |
rgalla9146 |
Apr 10 2017, 07:38 PM
Advanced Member Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is it possible to test a LSD on the bench ?
Can you describe how it is done ? I want to determine the condition my unit. |
mgphoto |
Apr 11 2017, 10:29 AM
Is it possible to test a LSD on the bench ? Can you describe how it is done ? I want to determine the condition my unit. Yes factory repair manual has the procedure, with pictures and self fabricated tools. The ZF LSD unit assembled with drive flanges and two cv bolts are screwed into a flange and locked in a vice, the other flange is turned with a torque wrench and the breakaway point or torque is measured. There is a specific torque that the factory uses but all bets are off as the orignal parts are NLA and I believe the "cup washers" have more pressure than the orignal "spring plates". What is being measured is the "locking force" of the clutch packs, lower the breakaway point or torque, the lower the locking force. Mike |
Lo-Fi Version | Time is now: 26th June 2024 - 12:55 AM |
