sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I've got stubs and hubs from a 69 911 and a 915 tranny from a an 85. When I went to measure up the axle flanges from the 915 it matches the diameter of the stubs from the 69. Only thing is, is the 69 stubs mount the cv's with 4 bolts and 2 pins. What I was thinking is to have the 2 roll pin holes welded up and then drilled and tapped with the same size bolt hole as the other 4 bolts.
btw the 915 axle flanges and the stubs both use 10mm bolts. Has anyone done this type of modification and on a safety stand point is this something that would be avoided. |
sj914 |
QUOTE(Britain Smith @ Oct 27 2004, 09:47 AM) So what would you say a set of '69 hubs are worth? Possibly ones that look like this... (IMG:http://www.britainsmith.com/Ebay/10-18-04/images/153_0013_JPG.jpg) -Britain I bought a set of those minus stubs for 80.00 |
Lo-Fi Version | Time is now: 26th June 2024 - 09:38 AM |
