Ford Solenoid Hot Start installation instructions, Mark Henry's method |
Mark Henry |
Apr 24 2017, 05:12 AM
Because this comes up so often I decided to make a tutorial on how I install the Ford solenoid.
The Ford solenoid fixes the common hot start problem of Bosch starter solenoid and it also reduces the load on the ignition switch. Although these instructions are for the 914 all aircooled VW's and Porsche often suffer from this problem and with minor changes this can be done to any car. The issue occurs because the Bosch starter solenoid needs a full 9 volts to kick in. The combination of age, heat, corrosion, many connectors, a small ignition switch and wiring running to the dash and back can degrade the volts to less than the 9V required. The Ford solenoid only needs about 3 volts for the 12V version and even less for the 6V which for our purpose works no problem. My installation drills no holes in the car, not a single factory wire is cut, no in-line fuses, fully reversible and simple with no added bullshit. Please this is not a discussion on if you prefer the wimpy (IMO) Bosch horn relay, want to cut and hack in a new wire or believe throat singing Vajrayana chants is a better method, start you're own thread. Of course as with any electrical trouble shooting the first order of business is always clean all of your grounds and make sure the chassis to transmission ground strap is in place and in good condition. I'll start right away with the money shot of the completed installation to show how clean this can be done. Attached image(s) |
GeorgeRud |
Apr 24 2017, 02:44 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I wonder if there's another design that would allow the solenoid to mount utilizing both ears rather than one? As the one side is at a constant +12 volts, I'd be concerned about vibration eventually causing the solenoid mount to crack and create a mother of a short if that terminal contacted the grounded metal. Perhaps a bracket using two of the transmission to engine mounting bolts would make a sturdier, vibration resistant design. Yes, I am a belt and suspenders type of guy, but have witnessed what happens when a battery positive terminal touches the metal of the body firsthand.
Still, great write up on the wiring for the solenoid. |
Mark Henry |
Apr 25 2017, 03:30 PM
I wonder if there's another design that would allow the solenoid to mount utilizing both ears rather than one? As the one side is at a constant +12 volts, I'd be concerned about vibration eventually causing the solenoid mount to crack and create a mother of a short if that terminal contacted the grounded metal. Perhaps a bracket using two of the transmission to engine mounting bolts would make a sturdier, vibration resistant design. Yes, I am a belt and suspenders type of guy, but have witnessed what happens when a battery positive terminal touches the metal of the body firsthand. Still, great write up on the wiring for the solenoid. I've never had an issue and one car I did, a summer DD, has had the same repair for close to 25 years without being touched. If you're worried about the nut coming loose just use some red loctite on it. Same with the wires, since the solenoid is attached to the tranny it doesn't see a huge amount of vibration. If the solenoid was screwed to the body then I'd worry about the connectors and vibration. I've also never seen heat as an issue as well. Not my first rodeo, I've done this mod countless times since around 1990. |
Lo-Fi Version | Time is now: 15th January 2025 - 06:58 AM |
