McMark |
I'm in the process of installing the Beta KitCarlson EMS. Today it ran. I've been working on modifying the wiring harness to match the stock layout. I had one wire in the wrong place today which made it keep running even when the key was off. Fixed that and now it idles great.
Things I've done so far: - Modify the wiring harness. - Buy plug wires that will work with the new coil. - Made an adapter plate to mount the coil in the stock location. Things I still have to do: - Send the harness to Jeff B. for replication. - Fine tune the engine. - Make a mounting plate for the brain to put it in the stock location. |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Thanks Jeff,
Mark, I recall seeing the adapter in the box you gathered everything in. I'll look around tomorrow for it however. B |
Lo-Fi Version | Time is now: 26th June 2024 - 08:47 AM |
