oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
While refueling my 914 for the last 20 years, I have had to hold the gas pump nozzle anti vapor ring up while pumping the gas in because the pump nozzles don't go into the tank far enough. I finally cut a ring of tubing (almost any kind will work) and attached it with a chain near the tank. Here's a pic of the ring and attachment, how it goes on the tank, and the pump in it. The inside diameter of the ring must be greater than 1 5/8 inches and no larger OD than 2 1/2 inches, and the length should be between 1/2 and 5/8 of an inch to space the pump nozzle properly. It's so nice to put the nozzle in now and click it on till the tank is full!
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
I like this a lot! This problem is annoying. I think I will just keep the spacer on the floor of the trunk though. (IMG:style_emoticons/default/first.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 07:14 AM |
