Got tired of holding the gas pump nozzle.., Easy fix |
oakdalecurtis |
Apr 28 2017, 08:08 PM
Oakdalecurtis Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
While refueling my 914 for the last 20 years, I have had to hold the gas pump nozzle anti vapor ring up while pumping the gas in because the pump nozzles don't go into the tank far enough. I finally cut a ring of tubing (almost any kind will work) and attached it with a chain near the tank. Here's a pic of the ring and attachment, how it goes on the tank, and the pump in it. The inside diameter of the ring must be greater than 1 5/8 inches and no larger OD than 2 1/2 inches, and the length should be between 1/2 and 5/8 of an inch to space the pump nozzle properly. It's so nice to put the nozzle in now and click it on till the tank is full!
forrestkhaag |
Apr 29 2017, 01:51 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I wonder if Mikey has seen this.................. It could be made to fit inside of the filler neck to avoid spillage which Jerry will have you arrested for...... (IMG:style_emoticons/default/sheeplove.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 07:51 AM |
