Got tired of holding the gas pump nozzle.., Easy fix |
oakdalecurtis |
Apr 28 2017, 08:08 PM
Oakdalecurtis Group: Members Posts: 1,336 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
While refueling my 914 for the last 20 years, I have had to hold the gas pump nozzle anti vapor ring up while pumping the gas in because the pump nozzles don't go into the tank far enough. I finally cut a ring of tubing (almost any kind will work) and attached it with a chain near the tank. Here's a pic of the ring and attachment, how it goes on the tank, and the pump in it. The inside diameter of the ring must be greater than 1 5/8 inches and no larger OD than 2 1/2 inches, and the length should be between 1/2 and 5/8 of an inch to space the pump nozzle properly. It's so nice to put the nozzle in now and click it on till the tank is full!
dlkawashima |
Apr 30 2017, 10:57 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I think this problem mainly exists on the later tanks ...
I don't have a problem with the '73 as you can see by the picture below, but with the '75 I do have to hold the nozzle while filling. Thanks for the tip! |
Lo-Fi Version | Time is now: 25th September 2024 - 10:45 PM |
