1973 Porsche 1.7 D-Jet, No power to two injectors |
crodog |
Apr 30 2017, 08:38 AM
Newbie Group: Members Posts: 4 Joined: 19-March 17 From: Wisconsin Member No.: 20,942 Region Association: None |
I have power to #3 and #4 injectors but not #1 and #2. The car will run but it is missing on 1 & 2. I have spark but when I pull the wires off the injectors nothing happens. After testing more I found I have no power to both of them. Where does the power come from? Do I need to look at the releasing contacts at the base of the distributor?
crodog |
Apr 30 2017, 11:03 AM
Thx for the info. I will hunt down the grounds. Maybe my way of checking for that was not so good. I used an Ohms meter and removed the plug from the injector, put one lead into the plug and the other to a good ground. I got 0 when I touched the lead to a good ground. Maybe this is not a good test for that.
larss |
Apr 30 2017, 11:14 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Thx for the info. I will hunt down the grounds. Maybe my way of checking for that was not so good. I used an Ohms meter and removed the plug from the injector, put one lead into the plug and the other to a good ground. I got 0 when I touched the lead to a good ground. Maybe this is not a good test for that. Well not so bad test! You should get 0 ohms (or close to yo 0) on one of the two terminals in each plug meaning that the ground is OK. /Lars S |
Lo-Fi Version | Time is now: 25th June 2024 - 09:58 PM |
