litesonic |
Newbie ![]() Group: Members Posts: 17 Joined: 8-January 15 From: Fort Collins CO Member No.: 18,307 Region Association: None ![]() |
Based on my research, these are old school centerlines.
Before I post for sale... what value do you think they have? Specs: 4x130 15x5.5 With 195 60 tire 32.5 lbs. thanks! Attached thumbnail(s) ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
They may not be 914 offset, which should be ET40.
If a VW offset, then you'll have better luck over at TheSamba.com with the VW folks (Porsches are over there too). From your pic of one, it's been curbed & looks to have some oxidation damage around the center, so based on what other aftermarket wheels go for in better shape - you may only be looking at $100-200 for the set of 4. PS ... maybe $300 if the tiers are a year or so off date code. For a real ad, you'll need the offset & good pix front & back of all wheels, & I suggest that you spend some elbow grease to thoroughly clean them up to eliminate any dirt looking like oxidation or damage, if you want top dollar. PS "Barum" isn't a top tire brand - more of an econo tire, & the age will also be a factor in whether they're still driveable, so show pix of the DOT date code on each tire & tread + sidewalls both sides' condition for any cracking. GLWTS! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 26th June 2024 - 10:51 AM |
