Optimusglen |
Senior Member ![]() ![]() ![]() Group: Members Posts: 914 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest ![]() ![]() |
Hey all, my project is coming along and this weekend I will probably try the first start.
It was a rebuild down to the shortblock, 1911 with dual Webers. I've heard of a few methods for priming the oil chambers and wanted to see if there was a preferred method you guys use. Option 1: disconnect fuel pump and just crank it over until the oil pressure light goes out. Option 2: disconnect fuel pump and remove spark plugs and valve rocker assemblies to reduce load on the starter and crank. Turn over until oil pressure light goes out. Option 3: fabricate an oil can that can take air pressure, hose comes out and connected to where the oil pressure switch goes. Pressurize the can and push 2 qts into the engine, add the rest of the oil to the filler. Any other methods? |
Lo-Fi Version | Time is now: 25th June 2024 - 08:10 PM |
