billd |
Member ![]() ![]() Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 ![]() |
I'm in the process of replacing the stock latch on my front trunk lid with hood pins. To avoid hitting the bracing on the fiberglass lid, the pins need to be in at least 3.5 inches from the front and from the edge of the hood toward the headlight.
I riveted in a piece of aluminum angle between the "gutters" in the appropriate place and attempted to install a hood pin in this angle. However the pin is too high (even threaded all the way down) and at the wrong angle (Tilted too far forward). The angle matters because the clearance on the scuff plate is only about 0.62 inches. I'm about to fabricate a custom bracket to hold the pin at the right level and right angle. Before I spend a lot of time bending metal, does anyone have a photo of how this should be done? |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,536 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Thanks Jim...Bill the first picture is mine. I used nylon spacers....The pin is at 19 degs. so the hole does not have to be longated. The nice thing about the nylon on top and bottom is you can rotate the nylon shims to make fine adjustments front to back and side to side. The Kelly-Moss 914-6 GT build had the pins straight up from the gutters and just kinda bend (or bow) the fiberglass hood as it was put down. Best, Mark
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Thanks Jim...Bill the first picture is mine. I used nylon spacers....The pin is at 19 degs. so the hole does not have to be longated. The nice thing about the nylon on top and bottom is you can rotate the nylon shims to make fine adjustments front to back and side to side. The Kelly-Moss 914-6 GT build had the pins straight up from the gutters and just kinda bend (or bow) the fiberglass hood as it was put down. Best, Mark Glad you responded: I have a question; what is the material ( part) you used for the collar. If I go into the Hardware store, what am I looking for ? And how did you set up the piece to cut it at the 19 degree angle ? Really liked your set up; getting ready to do this One other question: what size hole in the hood for the pin ? Any issues in drilling through ? Thanks.... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:51 AM |
