billd |
Member ![]() ![]() Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 ![]() |
I'm in the process of replacing the stock latch on my front trunk lid with hood pins. To avoid hitting the bracing on the fiberglass lid, the pins need to be in at least 3.5 inches from the front and from the edge of the hood toward the headlight.
I riveted in a piece of aluminum angle between the "gutters" in the appropriate place and attempted to install a hood pin in this angle. However the pin is too high (even threaded all the way down) and at the wrong angle (Tilted too far forward). The angle matters because the clearance on the scuff plate is only about 0.62 inches. I'm about to fabricate a custom bracket to hold the pin at the right level and right angle. Before I spend a lot of time bending metal, does anyone have a photo of how this should be done? |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
A very smart Porsche guy told me the only authentic use of hood pins on a 914 front bonnet is when you have a fiberglass hood. Same thing goes for the rear rubber latches on the rear trunk lid.
I think that is sound policy. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
A very smart Porsche guy told me the only authentic use of hood pins on a 914 front bonnet is only when you have a fiberglass hood. Same thing goes for the rear rubber latches on the rear trunk lid. I think that is sound policy. Both my trunk lids are fiberglass. Maybe I should re-think this. But then again my car rarely sees 150 MPH. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:50 AM |
