> Generator Light, Is On
EdwardBlume
post May 18 2017, 12:25 PM
Was driving last week and the generator light came on, went off, came on again, and then it stayed on.
Belt is on, VR was swapped with another I have around (and another is on the way), ground at the tranny is connected and good, battery charged and tightened, fuses 8 & 9 are good and new, spun to make sure they are connected.
Voltage meter is showing 12 to 13.
Anything else I can troubleshoot before I pull the generator? (IMG:style_emoticons/default/dry.gif)
porschetub
post May 18 2017, 02:16 PM
IF the voltage is higher when running you have charge,do a load test,lights on ,stereo on,fan blower on max.................... this will tell you whats really happening,don't trust the amps gauge,put your meter directly on the battery,good luck.
EdwardBlume
post May 18 2017, 03:50 PM
QUOTE(porschetub @ May 18 2017, 01:16 PM) *
With the lights on and wipers going (no radio currently) at idle, I'm getting 11.8 on the battery.
Elliot Cannon
post May 18 2017, 07:40 PM
Group: Retired Members
QUOTE(Edward Blume @ May 18 2017, 02:50 PM) *
What does it read when you rev the engine above idle?
Edward Blume   Generator Light   May 18 2017, 12:25 PM
Edward Blume   And its running fine.....   May 18 2017, 12:26 PM
BillC   Check the voltage at the battery using a DVOM. Sh...   May 18 2017, 12:35 PM
Elliot Cannon   Check the voltage at the battery with the engine r...   May 18 2017, 12:35 PM
Edward Blume   Thanks guys. The battery is coming through at 12.2...   May 18 2017, 12:51 PM
porschetub   IF the voltage is higher when running you have cha...   May 18 2017, 02:16 PM
Edward Blume   IF the voltage is higher when running you have ch...   May 18 2017, 03:50 PM
Elliot Cannon   IF the voltage is higher when running you have c...   May 18 2017, 07:40 PM
Edward Blume   New alternator, battery, and voltage regulator. St...   Jun 21 2017, 07:06 PM
porschetub   New alternator, battery, and voltage regulator. S...   Jun 21 2017, 11:26 PM
Kansas 914   You don't have an LED in the gauge do you?   Jun 22 2017, 06:34 AM
Edward Blume   You don't have an LED in the gauge do you? N...   Jun 22 2017, 10:45 AM
Spoke   New alternator, battery, and voltage regulator. S...   Jun 23 2017, 07:40 PM
Krieger   Test the wire after the vr back to the light. Is ...   Jun 22 2017, 07:57 AM
Edward Blume   Test the wire after the vr back to the light. Is...   Jun 22 2017, 10:48 AM
rhodyguy   Good used (tested) or new on the alt change?   Jun 22 2017, 11:03 AM
Edward Blume   Good used (tested) or new on the alt change? Goo...   Jun 22 2017, 03:41 PM
Edward Blume   Here's the one I pulled. Looks like the boot m...   Jun 22 2017, 04:18 PM
GregAmy   Here's the one I pulled. Looks like the boot ...   Jun 23 2017, 07:49 AM
rhodyguy   Are there arching marks on the inside face of the ...   Jun 23 2017, 07:30 AM
914Tom   only my 2c. If Voltage is correct an it is so. Alt...   Jun 23 2017, 08:00 AM
Edward Blume   Thanks for the great information Spoke! I...   Jul 31 2017, 04:07 PM
porschetub   What did they find wrong with it ?   Jul 31 2017, 04:45 PM
Edward Blume   It tested good but when he opened it up, the diode...   Jul 31 2017, 05:01 PM
Edward Blume   I got the new alternator installed. Fully charged ...   Sep 28 2017, 03:09 PM
Spoke   I got the new alternator installed. Fully charged...   Sep 28 2017, 06:31 PM
Edward Blume   I got the new alternator installed. Fully charge...   Sep 28 2017, 09:16 PM
Edward Blume   I re-read your instructions to test it to ground. ...   Sep 28 2017, 03:38 PM
Perry Kiehl   $200 is a lot. The list for a Bosch reman at...   Sep 28 2017, 04:52 PM
Edward Blume   $200 is a lot. The list for a Bosch reman a...   Sep 28 2017, 09:02 PM
Spoke   Rob, Copying my PM to you with additional info: ...   Sep 28 2017, 06:25 PM
Edward Blume   Rob, Copying my PM to you with additional info: ...   Sep 28 2017, 09:13 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th March 2025 - 09:48 AM
