> Washer Nozzles
yeahmag
post May 11 2017, 04:42 PM
Seems like there is some wild pricing from cheap to expensive on replacement washer nozzles for the 914. Anybody have a recommended replacement?
914Sixer
post May 11 2017, 09:49 PM
Autohausaz.com
Chrome with check valve $19.55 70-73
Black plastic $5.27 74-76
Both have adjustable sprayer.
kgruen2
post May 25 2017, 02:03 AM
QUOTE(914Sixer @ May 11 2017, 08:49 PM) *
Autohausaz.com
What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable?
I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts?
jkb944t
post May 25 2017, 12:00 PM
QUOTE(kgruen2 @ May 25 2017, 12:03 AM) *
Autohausaz.com
I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds.
Jeff B
BillC
post May 25 2017, 12:35 PM
QUOTE(jkb944t @ May 25 2017, 02:00 PM) *
Autohausaz.com
Jeff B
Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented).
The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated.
kgruen2
post May 26 2017, 02:04 AM
QUOTE(BillC @ May 25 2017, 11:35 AM) *
Autohausaz.com
Jeff B
Thx guys for the responses. What I learned is that I should use them, regardless of the difference of opinion on aerodynamics.
yeahmag   Washer Nozzles   May 11 2017, 04:42 PM
Mikey914   There is a difference. the chrome ones have a cap...   May 11 2017, 05:46 PM
914Sixer   Autohausaz.com Chrome with check valve $19.5...   May 11 2017, 09:49 PM
kgruen2   Autohausaz.com Chrome with check valve $19....   May 25 2017, 02:03 AM
jkb944t   What do the check valves under the nozzles check...   May 25 2017, 11:59 AM
jkb944t   Autohausaz.com Chrome with check valve $19...   May 25 2017, 12:00 PM
BillC   [quote name='kgruen2' post='2489392' date='May 25...   May 25 2017, 12:35 PM
kgruen2   [quote name='kgruen2' post='2489392' date='May 2...   May 26 2017, 02:04 AM
jkb944t   [quote name='kgruen2' post='2489392' date='May 2...   May 26 2017, 05:49 AM
BillC   I stand corrected as that makes sense to me that ...   May 26 2017, 06:39 AM
kgruen2   I stand corrected as that makes sense to me that...   May 26 2017, 11:09 AM
BillC   [quote name='BillC' post='2489780' date='May 26 2...   May 26 2017, 12:55 PM
kgruen2   [quote name='BillC' post='2489780' date='May 26 ...   May 26 2017, 02:35 PM
Jonathan Livesay   [quote name='kgruen2' post='2489392' date='May 2...   May 28 2017, 01:18 PM
kgruen2   [quote name='BillC' post='2489546' date='May 25 2...   May 30 2017, 12:54 AM
Olympic 914   one of the original washers on my car broke when i...   May 25 2017, 06:54 AM
Larmo63   For no other reason, but that it is Friday nigh...   May 26 2017, 09:58 PM
kgruen2   For no other reason, but that it is Friday nig...   May 27 2017, 01:50 AM
23e Heure   I'm finding different parts for different year...   May 28 2017, 12:49 PM
Chris914n6   Most of the newer cars have a check value not far ...   May 28 2017, 01:15 PM
- Lo-Fi Version Time is now: 19th April 2025 - 06:55 AM
