> Washer Nozzles
yeahmag
post May 11 2017, 04:42 PM
Seems like there is some wild pricing from cheap to expensive on replacement washer nozzles for the 914. Anybody have a recommended replacement?
914Sixer
post May 11 2017, 09:49 PM
Autohausaz.com
Chrome with check valve $19.55 70-73
Black plastic $5.27 74-76
Both have adjustable sprayer.
kgruen2
post May 25 2017, 02:03 AM
QUOTE(914Sixer @ May 11 2017, 08:49 PM) *
Autohausaz.com
What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable?
I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts?
jkb944t
post May 25 2017, 12:00 PM
QUOTE(kgruen2 @ May 25 2017, 12:03 AM) *
Autohausaz.com
I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds.
Jeff B
BillC
post May 25 2017, 12:35 PM
QUOTE(jkb944t @ May 25 2017, 02:00 PM) *
Autohausaz.com
Jeff B
Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented).
The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated.
jkb944t
post May 26 2017, 05:49 AM
QUOTE(BillC @ May 25 2017, 10:35 AM) *
Autohausaz.com
Jeff B
I stand corrected as that makes sense to me that it is a high pressure zone but I still think it can pull the fluid out due to the venturi effect as the air passes over the nozzle.
Jeff B
BillC
post May 26 2017, 06:39 AM
QUOTE(jkb944t @ May 26 2017, 07:49 AM) *
Jeff B
Because that is a high-pressure area, it also means it's a low-flow area. The pressure is higher than any suction from any venturi effect. In fact, the pressure is higher than the pressure inside the trunk, so this would have the effect of pushing the fluid out of the nozzle and back into the reservoir, hence the need for the check valve.
Plus, if the check valve were oriented so that it would keep fluid from being sucked out of the nozzle, it would also prevent the fluid from being sprayed out.
yeahmag   Washer Nozzles   May 11 2017, 04:42 PM
Mikey914   There is a difference. the chrome ones have a cap...   May 11 2017, 05:46 PM
914Sixer   Autohausaz.com Chrome with check valve $19.5...   May 11 2017, 09:49 PM
kgruen2   Autohausaz.com Chrome with check valve $19....   May 25 2017, 02:03 AM
jkb944t   What do the check valves under the nozzles check...   May 25 2017, 11:59 AM
jkb944t   Autohausaz.com Chrome with check valve $19...   May 25 2017, 12:00 PM
BillC   [quote name='kgruen2' post='2489392' date='May 25...   May 25 2017, 12:35 PM
kgruen2   [quote name='kgruen2' post='2489392' date='May 2...   May 26 2017, 02:04 AM
jkb944t   [quote name='kgruen2' post='2489392' date='May 2...   May 26 2017, 05:49 AM
BillC   I stand corrected as that makes sense to me that ...   May 26 2017, 06:39 AM
kgruen2   I stand corrected as that makes sense to me that...   May 26 2017, 11:09 AM
BillC   [quote name='BillC' post='2489780' date='May 26 2...   May 26 2017, 12:55 PM
kgruen2   [quote name='BillC' post='2489780' date='May 26 ...   May 26 2017, 02:35 PM
Jonathan Livesay   [quote name='kgruen2' post='2489392' date='May 2...   May 28 2017, 01:18 PM
kgruen2   [quote name='BillC' post='2489546' date='May 25 2...   May 30 2017, 12:54 AM
Olympic 914   one of the original washers on my car broke when i...   May 25 2017, 06:54 AM
Larmo63   For no other reason, but that it is Friday nigh...   May 26 2017, 09:58 PM
kgruen2   For no other reason, but that it is Friday nig...   May 27 2017, 01:50 AM
23e Heure   I'm finding different parts for different year...   May 28 2017, 12:49 PM
Chris914n6   Most of the newer cars have a check value not far ...   May 28 2017, 01:15 PM
- Lo-Fi Version Time is now: 19th April 2025 - 06:56 AM
