911 E dizzy for early engine,, anyone had one machined for this application ? |
porschetub |
May 26 2017, 07:26 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Think it was Henry @ Supertech (Pelican forum guru) mentioned these work fine on an earlier motor but as I have found they need machining down to fit ,anyone done it ?
Appears the earlier cases up to 2.4 are the same size as any Bosch unit for 911/914 and Type 1 but after that they went to from 27 to 30mm body size. Have a excellent example and plan to lock out the retard on the advance plate. Think mb911 (Ben ) is planning using the same 006 unit on his motor. TIA. |
mb911 |
May 26 2017, 07:53 PM
914 Guru Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I sent my E dizzy to Henry in trade for a recurved 2.7 dizzy for my app as the E dizzy is a smaller diameter shaft then my 2.4 case as it changed midway on the 2.4 run probably when they went to the 7r case?
Lo-Fi Version | Time is now: 25th June 2024 - 05:57 PM |
