Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,597 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
eitnurg |
Nov 6 2016, 02:18 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
QUOTE There are certainly other ways to skin a cat. How about a Boxster trans ? I thought the problem was that the Boxster trans has no provision for a starter motor? Or am I missing something here? (They're certainly cheap, though.......) |
ClayPerrine |
Nov 6 2016, 05:11 AM
Life's been good to me so far..... Group: Admin Posts: 15,903 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE There are certainly other ways to skin a cat. How about a Boxster trans ? I thought the problem was that the Boxster trans has no provision for a starter motor? Or am I missing something here? (They're certainly cheap, though.......) I am building the adapter plate to put a G86-21 Boxster six speed behind my 964 motor. I will be documenting the whole process on World for everyone's enjoyment. Yes, there is an issue with locating the starter. I have it worked out in my head, but that plan is subject to change when the plan contacts reality. |
mb911 |
Nov 6 2016, 07:20 AM
914 Guru Group: Members Posts: 7,254 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
QUOTE There are certainly other ways to skin a cat. How about a Boxster trans ? I thought the problem was that the Boxster trans has no provision for a starter motor? Or am I missing something here? (They're certainly cheap, though.......) I am building the adapter plate to put a G86-21 Boxster six speed behind my 964 motor. I will be documenting the whole process on World for everyone's enjoyment. Yes, there is an issue with locating the starter. I have it worked out in my head, but that plan is subject to change when the plan contacts reality. Oh that would be awesome.. |
Mark Henry |
May 27 2017, 05:41 PM
QUOTE There are certainly other ways to skin a cat. How about a Boxster trans ? I thought the problem was that the Boxster trans has no provision for a starter motor? Or am I missing something here? (They're certainly cheap, though.......) I am building the adapter plate to put a G86-21 Boxster six speed behind my 964 motor. I will be documenting the whole process on World for everyone's enjoyment. Yes, there is an issue with locating the starter. I have it worked out in my head, but that plan is subject to change when the plan contacts reality. Oh that would be awesome.. Yes a boxster has no provision for a starter, I really don't see how you can do it. I have a 1999, 996 trans here which I believe is the same trans (at least same case), I can post pic's if you like. I'll take a look at it right now. |
Lo-Fi Version | Time is now: 25th November 2024 - 02:23 PM |
