yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,448 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Seems like there is some wild pricing from cheap to expensive on replacement washer nozzles for the 914. Anybody have a recommended replacement?
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,117 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Autohausaz.com
Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. |
kgruen2 |
Member ![]() ![]() Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region ![]() |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? |
jkb944t |
Member ![]() ![]() Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None ![]() |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 604 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented). The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated. |
Jonathan Livesay |
Senior Member ![]() ![]() ![]() Group: Members Posts: 745 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None ![]() ![]() |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented). The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated. (IMG:style_emoticons/default/agree.gif) |
kgruen2 |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented). The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated. (IMG:style_emoticons/default/agree.gif) Alright. This is what I've found out. Old style versus new style: Old ones are chrome and better looking (small details count). Much more difficult to install. Have a female end for the check valve male end. Are much more expensive. Newer style: Much easier to install (they snap right in). Aren't as good looking. Have a male end to attach the hose to with a check valve installed somewhere between the reservoir and nozzle. Are slightly smaller in circumference so if your car has been painted with older style installed, a small ring of old paint will show. Are less expensive. I have a '73 2.0. I could not get the old style to seat properly no matter how hard I tried (including lubing with soap). I installed the later style with no problem. They were easier to hook up and snap into place. System works great. |
Lo-Fi Version | Time is now: 19th April 2025 - 06:56 AM |
