> Windshield Washer
lsintampa
post Jun 13 2013, 02:52 PM
75 914/4 2.0
I removed the old tubes for the windshield washer system - all of them. Read the tech article about hooking up motor to the system. Seems very straight forward.
There was a spare tire line that ran to the washer container. I assume it pressurized the tank so when you wanted to squirt some cleaner on your windshield there was something to push the fluid out.
A tube ran out the bottom all the way to the column then went into some turnabout nipple thing and came back out to the nozzles.
My question:
Is that turn around nipple thing the "release" of pressure that will allow fluid to flow?
That means it's mechanical? Or is it? Just curious how it works.
I noticed that there also is a switch that makes contact in the steering column when you pull back on the wiper arm. On my car, the black/brown wire up front was just cut off and hanging out. I'm not sure if I have intermittent wipers or not. There's no sign of a relay of any kind on the brace where the wiper motor is. Don't know how to tell, unless all 75's had em.
Anyway, I'm hoping that black/brown goes hot when the wiper arm is pulled back, cause that's how I hooking the washer motor up.
I'm really starting to enjoy this thing... gets better each day.
Len
914Sixer
post May 30 2017, 03:08 PM
The key to doing the conversion is the switch. Reproduction switches are now available, can't remember the part number off the top of my heard. Want to say it ends with the letter H
lsintampa   Windshield Washer   Jun 13 2013, 02:52 PM
kg6dxn   There is a mechanical valve in the turn signal sta...   Jun 13 2013, 03:16 PM
lsintampa   There is a mechanical valve in the turn signal st...   Jun 13 2013, 03:47 PM
Dave_Darling   There is a mechanical valve in the turn signal st...   Jun 13 2013, 06:54 PM
tomeric914   I am told that you can use a 924 wiper stalk and ...   Jun 30 2017, 06:38 PM
Valy   [quote name='Dave_Darling' post='1879578' date='J...   Jun 30 2017, 08:23 PM
orthobiz   The intermittent wiper is an additional position f...   Jun 13 2013, 03:52 PM
orthobiz   As a footnote, when Brad Mayeur spruced up my car ...   Jun 13 2013, 07:39 PM
bandjoey   See the classic thread. Someone here (Sir Andy?). ...   Jun 13 2013, 09:15 PM
23e Heure   See the classic thread. Someone here (Sir Andy?)....   May 30 2017, 01:39 PM
914_teener   http://www.914world.com/specs/tech_art.php   May 30 2017, 03:07 PM
914Sixer   The key to doing the conversion is the switch. Re...   May 30 2017, 03:08 PM
kgruen2   The key to doing the conversion is the switch. R...   May 31 2017, 02:10 AM
Olympic 914   The key to doing the conversion is the switch. ...   May 31 2017, 06:40 PM
kgruen2   [quote name='kgruen2' post='2491428' date='May 31...   Jun 1 2017, 01:56 AM
Firstcar   Anyone know the correct ID of the rubber tubing? ...   May 31 2017, 06:24 PM
rpc   Anyone know the correct ID of the rubber tubing? ...   Sep 11 2017, 05:31 PM
9fourteen14   75 914/4 2.0 I removed the old tubes for the win...   Jun 28 2017, 08:12 PM
Dave_Darling   Is the hose from the washer hooked up to the spare...   Jun 29 2017, 12:17 AM
9fourteen14   Problem: when i pull the washer switch towards ...   Jun 29 2017, 03:30 PM
kgruen2   The pressure in the spare tire needs to be greater...   Jun 30 2017, 03:31 AM
9fourteen14   hey guess what guys i was not putting enough air i...   Jul 1 2017, 04:33 AM
kgruen2   This was my solution to the toggle switch for wind...   Jul 3 2017, 02:38 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th April 2025 - 07:43 PM
