Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,597 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
Steve |
Jun 1 2017, 08:43 AM
914 Guru Group: Members Posts: 5,728 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Curious what the 915 guys are running for a shifter. I'm running a renshift, but I still nick reverse when shifting from 5th to 4th. I have spent way to many hours adjusting it, so I know it's as good as it gets. If I shift from 5th, let it settle in the center plane on its own, then I can shift into 4th without hitting reverse. I heard wevo is the best. I will try that next.
Lo-Fi Version | Time is now: 25th November 2024 - 02:19 PM |
