> Adding a 915 trans to a 6 conversion, There must be a better way
post Nov 5 2016, 07:46 AM
914-6 GT in waiting
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
Steve
post Jun 1 2017, 08:43 AM
Curious what the 915 guys are running for a shifter. I'm running a renshift, but I still nick reverse when shifting from 5th to 4th. I have spent way to many hours adjusting it, so I know it's as good as it gets. If I shift from 5th, let it settle in the center plane on its own, then I can shift into 4th without hitting reverse. I heard wevo is the best. I will try that next.
naro914
post Jun 1 2017, 09:12 AM
Losing my mind...
QUOTE(Steve @ Jun 1 2017, 10:43 AM) *
I use Rennshift and never nicked reverse or had any issues.
My set up:
Rennshift with Tangerine Racing shift linkage kit to Vellios side shift conversion.
Chris Foley made me an intermediate adjustment piece that allowed for minor length adjustment between the rod in the center tunnel to the Tangerine shift rod outside the firewall. Plus we had to make a small spacer to adapt the linkage parts to the Vellios console.
mepstein   Adding a 915 trans to a 6 conversion   Nov 5 2016, 07:46 AM
GeorgeRud   Even if you run a cable shifter setup, you still w...   Nov 5 2016, 08:07 AM
mepstein   Yes, flipping the ring and pinion is a given. That...   Nov 5 2016, 08:18 AM
ConeDodger   McMark at Original Customs has a cable shift solut...   Nov 5 2016, 08:21 AM
SirAndy   McMark at Original Customs has a cable shift solut...   Nov 5 2016, 10:42 AM
mepstein   McMark at Original Customs has a cable shift solu...   Nov 5 2016, 11:08 AM
SirAndy   My 915 is patiently waiting for the OC cable shift...   Nov 5 2016, 11:48 AM
ConeDodger   [quote name='mepstein' post='2419883' date='Nov 5...   Nov 5 2016, 07:58 PM
mepstein   [quote name='mepstein' post='2419883' date='Nov ...   Nov 5 2016, 08:07 PM
ConeDodger   [quote name='ConeDodger' post='2420073' date='Nov...   Nov 5 2016, 08:57 PM
914forme   Is there any reason I shouldn't consider work...   Nov 5 2016, 09:14 AM
mepstein   I'm very encouraged to see an existing solutio...   Nov 5 2016, 12:26 PM
rgalla9146   Is there any reason I shouldn't consider work...   Nov 5 2016, 06:42 PM
larryM   check this - apparently Martin's parts ??? h...   May 29 2017, 09:45 PM
porschetub   check this - apparently Martin's parts ??? ...   May 30 2017, 12:23 AM
larryM   [quote name='larryM' post='2490988' date='May 30 ...   May 31 2017, 02:42 PM
914forme   :agree: Boxster fits the space even better, and we...   Nov 5 2016, 07:40 PM
eitnurg   I thought the problem was that the Boxster trans...   Nov 6 2016, 02:18 AM
ClayPerrine   I thought the problem was that the Boxster tran...   Nov 6 2016, 05:11 AM
mb911   I thought the problem was that the Boxster tra...   Nov 6 2016, 07:20 AM
Mark Henry   [quote name='ClayPerrine' post='2420170' date='No...   May 27 2017, 05:41 PM
914forme   Large enough demand for said combo I am sure some ...   Nov 6 2016, 07:09 AM
McMark   Step 1: Build a mount that doesn't cost ...   Nov 6 2016, 08:18 AM
396   Well, I'm happy to see that there's intere...   Nov 6 2016, 09:33 AM
ConeDodger   Well, I'm happy to see that there's inter...   Nov 6 2016, 03:13 PM
ClayPerrine   Clay's objective is very interesting. Especi...   Nov 7 2016, 01:21 PM
396   Clay's objective is very interesting. Espec...   Nov 7 2016, 01:34 PM
Steve   I'm running the Martin Bott kit on an 86 915 g...   Nov 6 2016, 09:57 AM
396   I'm running the Martin Bott kit on an 86 915 ...   Nov 6 2016, 02:15 PM
McMark   Whoops. Forgot my picture.   Nov 6 2016, 10:41 AM
mepstein   Whoops. Forgot my picture. Cool!   Nov 6 2016, 11:05 AM
rgalla9146   Attached are pictures of a hangar and an idea for ...   Nov 6 2016, 11:33 AM
eitnurg   Hopefully quite soon.......after despairing of t...   Nov 6 2016, 01:08 PM
mb911   Is length an issue for the booster trans?? I know ...   Nov 6 2016, 02:21 PM
jim912928   McMark...just south of you about 1 1/2 hours. I...   Nov 6 2016, 06:26 PM
jim912928   any updates on 915 setup or boxster tranny setup?   May 26 2017, 09:26 PM
ConeDodger   any updates on 915 setup or boxster tranny setup?...   May 26 2017, 11:04 PM
Steve   It's only money.. I have 10k in my Martin Bot...   May 27 2017, 11:14 AM
mepstein   I'm not interested in a boxter trans for my ca...   May 27 2017, 06:18 PM
Steve   Looks more like a poor copy of the vellios kit.   May 29 2017, 10:26 PM
Racer Chris   Looks more like a poor copy of the vellios kit. ...   May 30 2017, 06:39 AM
Steve   Looks more like a poor copy of the vellios kit. ...   May 30 2017, 07:42 AM
GeorgeRud   Vellios had some great ideas, and his 915 trans co...   May 30 2017, 07:41 AM
Beach914   Not doing anything with it at the moment but next ...   May 30 2017, 07:49 AM
Steve   Not doing anything with it at the moment but next...   May 30 2017, 12:46 PM
naro914   Our race car "Papa Smurf" has a 915 with...   May 31 2017, 04:13 PM
eitnurg   Ditto.   Jun 1 2017, 04:22 AM
Steve   Curious what the 915 guys are running for a shifte...   Jun 1 2017, 08:43 AM
naro914   Curious what the 915 guys are running for a shift...   Jun 1 2017, 09:12 AM
GeorgeRud   I'm using the stock 915 shift console with my ...   Jun 1 2017, 09:02 AM
mepstein   I'd like to make one of these work   Jun 1 2017, 07:13 PM
Dr Evil   :popcorn:   Jun 4 2017, 08:13 AM
Steve   :popcorn: See what you missed? Absolutely nothi...   Jun 4 2017, 04:00 PM
Jetsetsurfshop   :popcorn:   Jun 3 2018, 12:27 PM
Steve   Don't hold your breath waiting for this... I...   Jun 3 2018, 01:20 PM
Dr Evil   Don't hold your breath waiting for this... I...   Jun 4 2018, 12:56 PM
Jay Wellwood   Any update to this topic? Quite interested in usi...   Aug 3 2019, 11:55 AM
Steve   :popcorn: There’s a vellios 915 in the classifie...   Aug 3 2019, 03:15 PM
burton73   http://www.cableshift.com/ this is what I am goin...   Aug 4 2019, 10:40 PM
dr914@autoatlanta.com   As the owner of two 914s with 915 conversions (one...   Aug 5 2019, 07:50 AM
mepstein   I already have the parts. Early mag trans, cable s...   Aug 5 2019, 08:04 AM
naro914   901 with the stronger intermediate plate works ...   Aug 5 2019, 11:14 AM
mepstein   901 with the stronger intermediate plate works...   Aug 5 2019, 12:38 PM
aturboman   Good timing on this topic figured I'd share my...   Aug 5 2019, 11:04 AM
Cairo94507   Damn you guys! I have been longing for the 91...   Aug 5 2019, 01:36 PM
Dr Evil   Damn you guys! I have been longing for the 9...   Aug 5 2019, 01:53 PM
mepstein   Damn you guys! I have been longing for the ...   Aug 5 2019, 03:47 PM
naro914   ^^ Like Mark said... our car Huey has a stock 3.2 ...   Aug 5 2019, 07:14 PM
John   I hope this thread is still active and not a dead ...   Aug 6 2019, 09:14 AM
dr914@autoatlanta.com   when we used the vellios kit before it passed into...   Aug 6 2019, 09:18 AM
36 User(s) are reading this topic (36 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th November 2024 - 02:46 PM
