> 914-6 runs HOT - Part 2
767driver
post Jun 13 2017, 02:39 PM
Some of you may remember my initial thread about 914-6 oil temps here...
http://www.914world.com/bbs2/index.php?sho...%20hot&st=0
I was hopeful that re-installing the ducts from the fan housing to the heat exchangers would solve my high oil temps. Well...it solved one of the causes of my high oil temps. Now that I have driven the car on 2 multi-day tours through California I can unfortunately report that the issue is not fully corrected.
With the benefit of hindsight I now know that as road speeds increase the airflow through the engine compartment is insufficient to keep the oil temp in check. Running through the gears on tighter 2 and 3rd gear roads are no problem. It's the more open 4th and 5th gear runs (high road speeds) that are causing the problem now.
Now it looks like we are dealing with 2 options. The first is to install a faster-turning 1.9 to 1 ratio fan setup. This will increase airflow through the engine compartment but will make more noise and take a few HP to run. The second option is to add an external oil cooler. The front-mounted cooler seems to be the tried-and-true solution but is expensive and invasive. Some folks have rigged up an external cooler with fan under the rear of the car.
I am soliciting thoughts, preferably from those with experience themselves, on these or any other options that may exist. I would appreciate any pictures of the various external oil cooler installations as well.
Many thanks,
Lee
porschetub
post Jun 13 2017, 03:38 PM
QUOTE(767driver @ Jun 14 2017, 08:39 AM) *
Many thanks,
Lee
I believe you had a heatexchanger issue @ the start,seems weird you have the issue back (IMG:style_emoticons/default/headbang.gif) .
Its hard to say but could this be a new issue ?.
Can't remember if anyone asked if your oil thermostat was working correctly ?,they aren't known to fail often but that wouldn't be helping your cause one bit.
Was your oil cooler cleaned when the engine was rebuilt ?,I don't mean a quick wash out,I washed mine out after a long period of soaking in solvent...it was filthy,I then had it ultrasonically cleaned,the mate doing it said it was still very dirty before that process.
You could change your fan speed but kinda thinking that's only a bandage for your issue really,unless you have the wrong pulley/s to start with.
767driver   914-6 runs HOT - Part 2   Jun 13 2017, 02:39 PM
frankiec@outrageous.net   I have a 3.2 with the oil cooler mounted in the pa...   Jun 13 2017, 03:14 PM
767driver   I have a 3.2 with the oil cooler mounted in the p...   Jun 13 2017, 03:33 PM
mepstein   I would think a rear mount cooler might do the job...   Jun 13 2017, 03:20 PM
brant   I run the faster fan speed system and found minima...   Jun 13 2017, 03:26 PM
porschetub   Some of you may remember my initial thread about ...   Jun 13 2017, 03:38 PM
patssle   I tried going without an oil cooler on my 3.0 - no...   Jun 13 2017, 05:06 PM
767driver   porschetub... I do not believe this is a new prob...   Jun 13 2017, 05:10 PM
porschetub   porschetub... I do not believe this is a new pro...   Jun 13 2017, 05:40 PM
Perry Kiehl   I put a Mocal 24 or 21 row cooler in the right rea...   Jun 13 2017, 05:38 PM
buck toenges   I put a Mocal 24 or 21 row cooler in the right re...   Jun 13 2017, 06:28 PM
ConeDodger   First of all, gauge and sender compatible? Your 4...   Jun 13 2017, 09:46 PM
porschetub   First of all, gauge and sender compatible? Your ...   Jun 13 2017, 11:49 PM
767driver   First of all, gauge and sender compatible? Your ...   Jun 14 2017, 10:53 AM
Justinp71   First of all, gauge and sender compatible? Your...   Jun 14 2017, 05:26 PM
767driver   [quote name='767driver' post='2496494' date='Jun ...   Jun 14 2017, 05:29 PM
Justinp71   First of all, gauge and sender compatible? Your...   Jun 14 2017, 06:20 PM
BK911   I still think you have an obstruction partially bl...   Jun 14 2017, 07:11 AM
6freak   check the cooling hoses ,might have came loose a...   Jun 14 2017, 08:02 AM
mepstein   My belief is that 911 engines get most of their ai...   Jun 14 2017, 11:44 AM
mskala   You can get increased fan speed without going all ...   Jun 14 2017, 12:32 PM
MJHanna   I used a Setrab FP920M22 IFeaturing a Setrab ProL...   Jun 14 2017, 06:31 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 03:40 AM
