914-6 runs HOT - Part 2 |
767driver |
Jun 13 2017, 02:39 PM
Newbie Group: Members Posts: 34 Joined: 13-January 12 From: Baltimore, MD Member No.: 14,002 Region Association: MidAtlantic Region |
Some of you may remember my initial thread about 914-6 oil temps here...
http://www.914world.com/bbs2/index.php?sho...%20hot&st=0 I was hopeful that re-installing the ducts from the fan housing to the heat exchangers would solve my high oil temps. Well...it solved one of the causes of my high oil temps. Now that I have driven the car on 2 multi-day tours through California I can unfortunately report that the issue is not fully corrected. With the benefit of hindsight I now know that as road speeds increase the airflow through the engine compartment is insufficient to keep the oil temp in check. Running through the gears on tighter 2 and 3rd gear roads are no problem. It's the more open 4th and 5th gear runs (high road speeds) that are causing the problem now. Now it looks like we are dealing with 2 options. The first is to install a faster-turning 1.9 to 1 ratio fan setup. This will increase airflow through the engine compartment but will make more noise and take a few HP to run. The second option is to add an external oil cooler. The front-mounted cooler seems to be the tried-and-true solution but is expensive and invasive. Some folks have rigged up an external cooler with fan under the rear of the car. I am soliciting thoughts, preferably from those with experience themselves, on these or any other options that may exist. I would appreciate any pictures of the various external oil cooler installations as well. Many thanks, Lee |
ConeDodger |
Jun 13 2017, 09:46 PM
Apex killer! Group: Members Posts: 23,877 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
First of all, gauge and sender compatible?
Your 4th and 5th gear problem is fan speed. I have confirmed that with CHT. As soon as you go into 5th gear your CHT starts to rise. The rise in oil temp is just the response. I have a front cooler and an incompatible sender. I've confirmed my temps with a pyrometer as much less than the gauge says... Bitch is lying to me! (IMG:style_emoticons/default/av-943.gif) |
porschetub |
Jun 13 2017, 11:49 PM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
First of all, gauge and sender compatible? Your 4th and 5th gear problem is fan speed. I have confirmed that with CHT. As soon as you go into 5th gear your CHT starts to rise. The rise in oil temp is just the response. Yes very true and there is a drop in oil pressure around 200 + oil temp will be noticeable as the oil thins out,ask me how I know when my gearshift screwed up and I limped home in a high gear...fan speed caused this as well as a hot day. People get confused about how an aircooled engines works ,its about the oil cooling that has a big impact on running temp. |
Lo-Fi Version | Time is now: 15th January 2025 - 03:47 AM |
