> What did I do or miss?, All better now!
arne
post Jun 20 2017, 03:51 PM
Serial Rescuer of old vehicles...
Background - I got the engine in my '73 2.0 (D-jet) running a while back (after several years slumber). It actually was running pretty decently, other than a spastic AAR. But it had many oil leaks, so I dropped it to get to everything easier.
While it was out, I replaced all the vacuum lines, and a bunch of oil seals and such. AAR was disassembled and refurbished (as best I could). Eliminated the decal valve. No other injection work.
Now that the engine is in the car, it is running way rich, even when warm. So much so that it loads up after a bit and won't rev, and left to idle it will load up and die. AAR now appears to be working fairly well, once warmed there is little or no vacuum at that hose.
Since there really weren't many changes, I'm thinking this must be something fairly simple. Any suggestions?
arne
post Jun 20 2017, 07:42 PM
Fuel lines appear to be correct. Nothing is unplugged. Baffling. It ran pretty good before the engine drop, but not after.
arne   What did I do or miss?   Jun 20 2017, 03:51 PM
ConeDodger   Cylinder head temp sensor is disconnected?   Jun 20 2017, 04:08 PM
arne   Cylinder head temp sensor is disconnected? If so...   Jun 20 2017, 04:10 PM
Rand   It's running but way rich... Check the MPS. Do...   Jun 20 2017, 04:11 PM
arne   It's running but way rich... Check the MPS. D...   Jun 20 2017, 04:13 PM
arne   MPS in the car now does hold vacuum. The "spa...   Jun 20 2017, 04:38 PM
Dave_Darling   A few things that come to mind that would make the...   Jun 20 2017, 04:54 PM
arne   I wonder if I got the fuel and return lines rever...   Jun 20 2017, 05:04 PM
arne   Fuel lines appear to be correct. Nothing is unplug...   Jun 20 2017, 07:42 PM
r_towle   Unplug the car cold start injector electrically an...   Jun 20 2017, 08:05 PM
arne   Well, things just kept getting worse, but I think ...   Jun 22 2017, 08:59 AM
euro911   ... or the fuel lines could be reversed.   Jun 22 2017, 09:50 PM
arne   ... or the fuel lines could be reversed. Thought...   Jun 22 2017, 09:59 PM
PlantMan   Did you ever disconnect the fuel pump power??? If ...   Jun 23 2017, 01:46 PM
euro911   Did you ever disconnect the fuel pump power??? If ...   Jun 23 2017, 03:01 PM
arne   Did you ever disconnect the fuel pump power??? If...   Jun 23 2017, 01:55 PM
rhodyguy   Start with the fuel sock visual inpection. Simply ...   Jun 23 2017, 02:12 PM
arne   Got it! It runs again! When dropping the ...   Jun 23 2017, 03:28 PM
euro911   :mueba:   Jun 23 2017, 06:53 PM
- Lo-Fi Version Time is now: 19th April 2025 - 01:12 PM
