> Windshield install with butyl - is butyl primer needed?
Kansas 914
post Jun 23 2017, 07:41 AM
I have brand new paint on the car. I remember the last time I had a windshield installed by I don't think the installer used primer.
Is it best to prime the frame first and is butyl primer the right stuff?
Like this? https://www.amazon.com/CRL-Pinchweld-Primer...uct_top?ie=UTF8
Kansas 914   Windshield install with butyl - is butyl primer needed?   Jun 23 2017, 07:41 AM
76-914   I did not use any however I did prep with Lacquer ...   Jun 23 2017, 07:48 AM
Mark Henry   What size is the correct butyl...it's the tape...   Jun 23 2017, 08:00 AM
mepstein   What size is the correct butyl...it's the tap...   Jun 23 2017, 08:07 AM
Mark Henry   What size is the correct butyl...it's the ta...   Jun 23 2017, 08:09 AM
Kansas 914   [quote name='Mark Henry' post='2499469' date='Jun...   Jun 23 2017, 08:11 AM
Dave_Darling   Using the primer is not necessary, but it does hel...   Jun 23 2017, 09:24 AM
Perry Kiehl   Butyl primer will improve the seal. For $17 ...   Jun 23 2017, 09:35 AM
Kansas 914   Butyl primer will improve the seal. For $17...   Jun 23 2017, 10:45 AM
Mikey914   no primer required New paint not needed for sure....   Jun 23 2017, 02:39 PM
bbrock   With luck, I'll be facing this task in the not...   Jun 23 2017, 05:58 PM
Dave_Darling   Other than originality, are there reasons to stick...   Jun 23 2017, 10:07 PM
bbrock   Other than originality, are there reasons to stic...   Jun 23 2017, 10:49 PM
porschetub   Other than originality, are there reasons to stic...   Feb 12 2020, 01:04 PM
Perry Kiehl   Butyl tape is a consistent thickness, in this case...   Jun 23 2017, 09:10 PM
Montreal914   For the rear window, I have used 5/16 butyl about ...   Jun 23 2017, 09:45 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I h...   Feb 11 2020, 07:22 PM
bbrock   914rubber’s kit is 9.5 mm, which is 3/8”. I ...   Feb 11 2020, 08:55 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I...   Feb 11 2020, 09:11 PM
bbrock   [quote name='bbrock' post='2785159' date='Feb 11 ...   Feb 11 2020, 09:36 PM
stevegm   [quote name='stevegm' post='2785165' date='Feb 11...   Feb 11 2020, 09:55 PM
914werke   Other than originality, are there reasons to stic...   Feb 11 2020, 08:18 PM
ConeDodger   I did this alone but another set of hands would be...   Feb 11 2020, 08:30 PM
lierofox   https://www.amazon.com/gp/product/B00473W5V...=UTF...   Feb 11 2020, 08:32 PM
stevegm   https://www.amazon.com/gp/product/B00473W5V...=UT...   Feb 11 2020, 09:10 PM
lierofox   So you just put the primer on the windshield chan...   Feb 12 2020, 01:06 PM
mepstein   The warmer the better. Mark / Mikey explained the ...   Feb 12 2020, 01:20 PM
- Lo-Fi Version Time is now: 27th December 2024 - 07:48 PM
