> Windshield install with butyl - is butyl primer needed?
Kansas 914
post Jun 23 2017, 07:41 AM
I have brand new paint on the car. I remember the last time I had a windshield installed by I don't think the installer used primer.
Is it best to prime the frame first and is butyl primer the right stuff?
Like this? https://www.amazon.com/CRL-Pinchweld-Primer...uct_top?ie=UTF8
IronHillRestorations
post Jun 23 2017, 09:10 PM
I. I. R. C.
Butyl tape is a consistent thickness, in this case 5/16", which is required to get the windshield trim to attach properly.
I haven't installed a windshield in over 10 years, but I think the urethane doesn't come in a cord or tape, it's in a tube.
What I like about the primer, in addition to the fact that the butyl adheres and seals to it better, is it "paints" the windshield recess black, so you don't have edges of Saturn Yellow, or Marathon Blue (or whatever color your 914 is) peeking out from around the windshield perimeter
Kansas 914   Windshield install with butyl - is butyl primer needed?   Jun 23 2017, 07:41 AM
76-914   I did not use any however I did prep with Lacquer ...   Jun 23 2017, 07:48 AM
Mark Henry   What size is the correct butyl...it's the tape...   Jun 23 2017, 08:00 AM
mepstein   What size is the correct butyl...it's the tap...   Jun 23 2017, 08:07 AM
Mark Henry   What size is the correct butyl...it's the ta...   Jun 23 2017, 08:09 AM
Kansas 914   [quote name='Mark Henry' post='2499469' date='Jun...   Jun 23 2017, 08:11 AM
Dave_Darling   Using the primer is not necessary, but it does hel...   Jun 23 2017, 09:24 AM
Perry Kiehl   Butyl primer will improve the seal. For $17 ...   Jun 23 2017, 09:35 AM
Kansas 914   Butyl primer will improve the seal. For $17...   Jun 23 2017, 10:45 AM
Mikey914   no primer required New paint not needed for sure....   Jun 23 2017, 02:39 PM
bbrock   With luck, I'll be facing this task in the not...   Jun 23 2017, 05:58 PM
Dave_Darling   Other than originality, are there reasons to stick...   Jun 23 2017, 10:07 PM
bbrock   Other than originality, are there reasons to stic...   Jun 23 2017, 10:49 PM
porschetub   Other than originality, are there reasons to stic...   Feb 12 2020, 01:04 PM
Perry Kiehl   Butyl tape is a consistent thickness, in this case...   Jun 23 2017, 09:10 PM
Montreal914   For the rear window, I have used 5/16 butyl about ...   Jun 23 2017, 09:45 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I h...   Feb 11 2020, 07:22 PM
bbrock   914rubber’s kit is 9.5 mm, which is 3/8”. I ...   Feb 11 2020, 08:55 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I...   Feb 11 2020, 09:11 PM
bbrock   [quote name='bbrock' post='2785159' date='Feb 11 ...   Feb 11 2020, 09:36 PM
stevegm   [quote name='stevegm' post='2785165' date='Feb 11...   Feb 11 2020, 09:55 PM
914werke   Other than originality, are there reasons to stic...   Feb 11 2020, 08:18 PM
ConeDodger   I did this alone but another set of hands would be...   Feb 11 2020, 08:30 PM
lierofox   https://www.amazon.com/gp/product/B00473W5V...=UTF...   Feb 11 2020, 08:32 PM
stevegm   https://www.amazon.com/gp/product/B00473W5V...=UT...   Feb 11 2020, 09:10 PM
lierofox   So you just put the primer on the windshield chan...   Feb 12 2020, 01:06 PM
mepstein   The warmer the better. Mark / Mikey explained the ...   Feb 12 2020, 01:20 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 08:19 PM
