> Front sway bar parts -, Mounting plates question
seanpaulmc
post Jun 24 2017, 11:49 AM
1/17/2021 - resurrecting to ask new question.
Had the fuel tank out to replace the fuel line in the tunnel. From that I could see the front sway bar. Interestingly, the passenger side was connected and the driver side is not connected. In a box of parts that was with the car I found the drop link for the driver's side. It, however, is missing the cap and bolts to attach it to the bar. Does anyone know where I can get the piece to fit this part? Size of the bolts? Thank you.
Matty900
post Jun 24 2017, 12:37 PM
This is what the stock ones look like.
seanpaulmc   Front sway bar parts -   Jun 24 2017, 11:49 AM
michael7810   contact Bruce Stone (bdstone914), he should have w...   Jun 24 2017, 11:58 AM
bdstone914   contact Bruce Stone (bdstone914), he should have ...   Jun 24 2017, 04:15 PM
rhodyguy   Is that an H&H bar? Stock droplinks don't ...   Jun 24 2017, 12:23 PM
GeorgeRud   Looks like an old H&H swaybar. Should be easy...   Jun 24 2017, 12:24 PM
Matty900   This is what the stock ones look like.   Jun 24 2017, 12:37 PM
gandalf_025   That bar was made by H + H Specialties. The owner ...   Jun 24 2017, 03:32 PM
KevinW   I have one that I won't be using. The mate to ...   Jun 24 2017, 03:43 PM
seanpaulmc   Old thread. I know I should be long past this work...   Jan 17 2022, 08:11 PM
rjames   914LTD and PMB both sell front sway bar mounts. ...   Jan 18 2022, 01:08 AM
mepstein   Bushings are easy to remove. Just heat with a torc...   Jan 17 2022, 08:15 PM
seanpaulmc   Here is a picture of the bar end and bushing. Bus...   Jan 19 2022, 04:13 PM
Superhawk996   That is an awful lot of front bar at 19mm. Stock ...   Jan 19 2022, 04:23 PM
roblav1   Concur with way too much front bar on that! U...   Jan 19 2022, 09:07 PM
Freezin 914   As others here have stated, for sure an H&H ba...   Jan 19 2022, 10:00 PM
bossboy302   This might help. The aftermarket kits that work wi...   Jan 19 2022, 10:14 PM
seanpaulmc   Hi All, Thanks for the replies. I’m still at i...   Jan 30 2022, 08:14 PM
gereed75   Sorry to contradict but I have the same H&H 19...   Jan 31 2022, 12:50 AM
Mikey914   Right here https://914rubber.com/front-suspension...   Jan 31 2022, 05:41 AM
seanpaulmc   Right here https://914rubber.com/front-suspensio...   Jan 31 2022, 11:24 AM
rhodyguy   Good picture. Darn U bolts. The shelve directly un...   Jan 31 2022, 07:58 AM
Mikey914   Yeah, saw that after ai posted. It was 3AM on a Fa...   Jan 31 2022, 11:54 AM
Montreal914   I am using that bar with the H&H arms on my ca...   Feb 1 2022, 09:37 AM
Superhawk996   You may have to consider something like this and t...   Feb 1 2022, 10:13 AM
seanpaulmc   I want you all to know I very much appreciate all ...   May 6 2022, 05:53 PM
rjames   Nice job. Glad to see the plates welded in properl...   May 6 2022, 06:26 PM
- Lo-Fi Version Time is now: 28th November 2024 - 12:32 PM
