> Starter Motor, 911 vs 914
paintracer1
post Jun 24 2017, 10:20 PM
I'm using a 1977s 2.7 as my engine for my conversion. Can i use the starter motor from my 911 with the 914 /901 trans. I have the correct KEP flywheel. Just wanted to make sure it would work so i don't mess anything up. Second question is if yes on the 911 starter motor will work how are 914 and 911 starter motors different? Thanks
GeorgeRud
post Jun 25 2017, 12:45 PM
There were two different hp ratings for the Bosch starters, but either should work. I'd recommend using a starter relay as well to get maximum voltage to the starter motor and be sure the ground strap on the transmission is corrosion free.
- Lo-Fi Version Time is now: 27th December 2024 - 12:03 AM
