> Gauging interest for a 914 breather/puke tank, for 914/6 but could be modified to use on any engine combo
Mark Henry
post Jun 13 2017, 11:13 AM
that's what I do!
I built this as my very first aluminum TIG welding project, welds are definitely not up to Ben's standards, but I'm starting to get the hang of it. Bit more practice an I should have decent welds. Also the aluminum was a scrap sheet that been sitting outside for years, so that likely didn't help matters.
But overall seeing as it's my first effort I'm pretty happy with it.
Would do a couple things different for a short run production, use the next size up petcock valve, weld the baffles in a bit different, etc.
I made it to clear the factory trunk springs, but not intrude into the engine bay much. It has a petcock and a tube, so to drain you stick an oil pan under the /6 cooler and open the valve. It's fully baffled and holds over a quart of puke. The barb's are 1" but I could also check out what's involved with using AN fittings.
I would likely have them power coated semi-gloss black.
I have the patterns for it so it would be easy to make more.
I have to check the price of materials, parts, powder coating, etc, but I'm thinking $150-$175, or $200 + ship and I supply the black braid hose and clamps.
So is there any interest? (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-26-1497237833.jpg)(IMG:http://www.914world.com/bbs2/uploads/post-26-1497237851.jpg)
Mike D.
post Jun 25 2017, 01:22 PM
OK, It runs now, and pretty good too!
I'd be interested, anything is better than what i have now. Which is nothing... doh!
Mark Henry   Gauging interest for a 914 breather/puke tank   Jun 13 2017, 11:13 AM
6freak   did you put steel wool inside , I heard it helps....   Jun 13 2017, 02:58 PM
6freak   did you put steel wool inside , I heard it helps...   Jun 14 2017, 08:44 AM
Mark Henry   I like the design a lot! Does it fit with a...   Jun 14 2017, 12:12 PM
Mblizzard   I like the design a lot! Does it fit with ...   Jun 14 2017, 12:56 PM
SirAndy   My tank is sealed Where does the pressure go then?...   Jun 14 2017, 01:23 PM
Mark Henry   My tank is sealed Where does the pressure go then...   Jun 14 2017, 02:06 PM
SirAndy   [quote name='SirAndy' post='2496525' date='Jun 14...   Jun 14 2017, 02:11 PM
Mark Henry   Ok, just checking. And yes, my current Gatorade ...   Jun 14 2017, 02:31 PM
Mark Henry   dp   Jun 14 2017, 02:15 PM
johnhora   Mark...that's a clever design...looks good too...   Jun 13 2017, 03:36 PM
JmuRiz   I like the design a lot! Does it fit with a ...   Jun 13 2017, 06:53 PM
Norskpole   I'd be interested in one   Jun 14 2017, 09:38 AM
Travis Neff   Interested   Jun 14 2017, 09:52 AM
Mblizzard   Interested. I always seem to have some oil inside ...   Jun 14 2017, 10:07 AM
rktmn247   Interested.   Jun 14 2017, 10:11 AM
Andyrew   I like it!!! Im building one out of st...   Jun 14 2017, 01:32 PM
Andyrew   Curious how you ran the inners and what kind of ba...   Jun 14 2017, 02:09 PM
LowBridge   well done... TIG welling aluminum is hard or was h...   Jun 14 2017, 03:53 PM
mb911   Mark, Nice design.. Don't worry not going to ...   Jun 14 2017, 04:18 PM
mmascari   I would be interested as well. I have been contemp...   Jun 14 2017, 08:04 PM
porschetub   Quote...oil puking out from a shit breather filter...   Jun 14 2017, 10:01 PM
Elliot Cannon   Quote...oil puking out from a shit breather filte...   Jun 14 2017, 10:26 PM
Mark Henry   Looks like I have to play with my nipples a bit ...   Jun 15 2017, 01:05 PM
Mblizzard   FYI ordered cheap transition puke box waiting on t...   Jun 15 2017, 05:25 PM
6freak   its more like steel brillow ,pretty heavy duty stu...   Jun 16 2017, 02:49 PM
Mark Henry   ...I have not found a good way to mount mine yet ...   Jun 16 2017, 03:34 PM
Mark Henry   Some smog hose and /6 tank questions. I take it t...   Jun 21 2017, 11:38 AM
mb911   Some smog hose and /6 tank questions. I take it ...   Jun 21 2017, 12:51 PM
SirAndy   Them green hoses were cheap ... :wavebye: http...   Jun 21 2017, 11:50 AM
Mark Henry   Them green hoses were cheap ... :wavebye: ...   Jun 21 2017, 12:47 PM
SirAndy   Are those rad/heater core hose? The guy at NAPA w...   Jun 21 2017, 02:38 PM
6freak   This is the one I made ! works perfect, in ...   Jun 25 2017, 06:41 AM
Mark Henry   Same area I mounted mine. :) I still have to cut...   Jun 25 2017, 07:05 AM
6freak   Same area I mounted mine. :) I still have to cu...   Jun 25 2017, 09:39 AM
Mark Henry   You should also take into consideration the rub...   Jun 25 2017, 09:49 AM
6freak   You should also take into consideration the ru...   Jun 25 2017, 12:13 PM
Mike D.   I'd be interested, anything is better than wha...   Jun 25 2017, 01:22 PM
raynekat   Definitely could be interested. Needs to fit in th...   Jun 25 2017, 09:14 PM
Mark Henry   Definitely could be interested. Needs to fit in t...   Jun 26 2017, 06:37 AM
Mark Henry   For the /4 version I'm thinking 3 inlets, two ...   Jun 26 2017, 07:01 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 10:02 AM
