> 914 and 550, both T4, One Cold Starts, the Other Doesn't, Why?
Tastyplacement
post Jun 24 2017, 08:11 PM
This is baffling to me. I have two type 4 cars, both have 914 motors and have a lot off commonality to them. My 914 starts cold no problem. My 550 replica is a total hassle to start cold.
The 914 which cold starts very easily:
-1.8 liter motor
-twin IDF 40 with no choke and no cold start circuit
Main Jets are 115
Idle Jets are 55
carbs were recently completely rebuilt
-Pertronix Ingnitor 1 points replacement
The 550 replica:
-2.3 liter motor
Main jets are 155
Idle jets are 65
carbs seem great, but haven't been thoroughly cleaned recently
-twin IDF 44 with no choke and no cold start circuit
-Pertronix Ignitor 3 points replacement
The 914, I pump the pedal once, car starts every time and is immediately steady. The 550, I have to pump the pedal 4 or 5 times and It'll fire quickly and die quickly. Once I do this a few times it'll run if I keep it at about 2000rpm by feathering throttle. Once it is warm, it's awesome.
r_towle
post Jun 25 2017, 01:31 PM
Custom Member
I may be wrong, but I think one of our vendors sells a throttle handle that allows you to set the throttle at a higher speed from inside the car when you start it up....its something that the six has, but I recall someone making it for the four...not sure.
For cold start, that camshaft will require some extra revs to warm it up prior to letting it idle...just normal.
Tastyplacement
post Jun 25 2017, 06:04 PM
How about going up one jet size (+5) on the idle jets?
I looked tonite and the Spyder has 50 idle jets, not sure why I thought they were larger.
QUOTE(r_towle @ Jun 25 2017, 02:31 PM) *
Tastyplacement   914 and 550, both T4, One Cold Starts, the Other Doesn't, Why?   Jun 24 2017, 08:11 PM
Rand   I've never had luck with carbs and no choke be...   Jun 24 2017, 08:13 PM
Tastyplacement   I've never had luck with carbs and no choke b...   Jun 24 2017, 10:40 PM
jvmarino   Maybe the spark plugs. My carb'd 914 2.0 was t...   Jun 24 2017, 08:21 PM
thelogo   I would think the more performance oriented Your ...   Jun 24 2017, 08:28 PM
arne   What cams in each?   Jun 24 2017, 08:47 PM
Tastyplacement   What cams in each? Actually, that's a good ...   Jun 24 2017, 10:38 PM
thelogo   I always thought cold start Meant like cold clima...   Jun 24 2017, 10:57 PM
Perry Kiehl   Performance cams usually mean less than stellar co...   Jun 25 2017, 11:38 AM
rhodyguy   Feather the throttle a bit on the big engine when ...   Jun 25 2017, 12:54 PM
r_towle   I may be wrong, but I think one of our vendors sel...   Jun 25 2017, 01:31 PM
Tastyplacement   How about going up one jet size (+5) on the idle j...   Jun 25 2017, 06:04 PM
Racer Chris   The 50s are too small for the 2.3L. 55 would be be...   Jun 26 2017, 09:31 AM
Tastyplacement   Thanks chris, I am going to try the 55s, which I h...   Jun 26 2017, 11:23 AM
porschetub   Wow huge jets...why,those mains are massive, what ...   Jun 29 2017, 11:34 PM
Racer Chris   Wow huge jets...why,those mains are massive, what...   Jun 30 2017, 08:38 AM
Rav914   Wow huge jets...why,those mains are massive, what...   Jun 30 2017, 08:29 AM
Edward Blume   :ttiwwp: Somebody had to do it. Lets see the 550 ...   Jun 30 2017, 09:47 AM
- Lo-Fi Version Time is now: 21st December 2024 - 11:14 PM
