BeemerSteve |
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest ![]() |
I have the daunting job of clearing out my interior and cutting my tunnel open to repair the clutch tube. Does anyone have tips on doing this job? Do the fuel lines need to be taken out? Humm.......maybe I should if they're still plastic.
I appreciate all your wisdom as I'm trying to gain some on my own. Thanks!! Steve |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
it the tube is loose but the firewall is still OK this means the middle bracket is still intact. the front bracket is the first to break.
in this case i weld a 1"x1" L-bracket to the tube. this minor solution is quick . you only have to remove the shifter and dont need to mess with fuel ines. i still stuff a wet rag against them just in case did i mention remove clutch cable... Attached thumbnail(s) ![]() |
cooper951 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None ![]() |
it the tube is loose but the firewall is still OK this means the middle bracket is still intact. the front bracket is the first to break. in this case i weld a 1"x1" L-bracket to the tube. this minor solution is quick . you only have to remove the shifter and dont need to mess with fuel ines. i still stuff a wet rag against them just in case did i mention remove clutch cable... I think my clutch tube may be loose up front. Where is this access point to the tunnel? Underneath where the shifter is? TIA |
Lo-Fi Version | Time is now: 27th June 2024 - 06:21 PM |
